Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Super Star Member jerrybob's Avatar
    Join Date
    Mar 2010
    Posts
    19,041
    Somewhere in Washington
    yanmar 186D....JD LT180....DR Brush Cutter
    Default Re: Pesky Beavers
    You should write your local congress person or the President......explain your beaver problem......and wait for an answer. You might want to say your beavers are low income or even illegally in the country. If you hear a drone....hide behind a standing tree and stay away from the beaver dam. If they don't destroy the dam.....they may give you an application for beaver food stamps. Hopefully....this would change the beavers food source and your problem will be gone. Good luck!
    Most of the stuff people worry about.......ain't never gonna happen anyway!
    Tacocat spelled backwards is Tacocat
  2. #12
    Join Date
    Jan 2012
    Posts
    1,418
    Ma
    Kubota b2920
    I find that preventing their damage is easier and better than elimination. There are so many that they just reappear. There are devices to keep water flowing so they can't dam it and we protect high value trees with wire or by keeping the waters edge open (they dislike open areas). Once a good number is reached the new ones leave so the population stabilizes. We have a lot in our pond and they do a good job with the downed trees and don't cause issues because they can't flood the area.
  3. #13
    New Member
    Join Date
    Aug 2012
    Posts
    9
    Chicago, IL
    55 Ford 650
    head over to trapperman.com and have a trapper out to take care of the beavers for you
  4. #14
    Super Star Member
    Join Date
    Sep 2000
    Posts
    11,543
    Triangle Of North Carolina
    JD 4700
    Beavers... Argh!
    Clemson came up with this device years ago. Basically, you poke a hole in the beaver dam and insert a PVC pipe which drains the beaver pond. Beavers are smart but not so smart to figure out the that the leak is from the end of the pipe. They can't stop the water from draining from the pond and leave.
    http://www.clemson.edu/psapublishing/pages/afw/afw1.pdf
    I have seen this work.
    Later,
    Dan
  5. #15
    Bronze Member mmurphydds's Avatar
    Join Date
    Dec 2012
    Posts
    52
    Fergus Falls, MN
    JD 4720
    Beaver = Large swimming Rat with large, flat tail.
    Elimination = Wait till they start swimming at dusk and sight in your favorite varmint or deer rifle
    Result = Many fewer beavers, sighted in rifle, much fun, great satisfaction!
    Mark
    JD 4720, 400X FEL, JD MX6 Brush Cutter, 72" JD 7-Iron MM mower, 7ft Farm King disk, 6ft LandPride scraper/pulverizer, 7ft King Kutter II rotary tiller, 7ft King Kutter landscape rake, 6ft Buhler box scraper, 2-row Yetter planter, 3pt quick hitch, 3pt trailer hitch lift, 3pt carryall, Hydraulic top link, Wallenstein BX62 chipper
    JD X720, 60" 7-Iron mower, 47" front-mount snowblower.
  6. #16
    Join Date
    Dec 2007
    Posts
    1,461
    Eastern Ontario
    Jinma 284(Spirit fel), MF 135 (MF200 fel)
    Are you upstream from me?
    With over thirty acres of marshland and a river on my property, even the authorities (county and Natural Resources) want me to control the population to avoid road washouts, flooded fields and many, many trees downed.
  7. #17
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,461
    Oklahoma
    JD cut
    Quote Originally Posted by Bladehauler View Post
    How do I get rid of beavers ?
    Texas Rodent and Predatory Animal Control Service, Fort Worth, TX
    FYI, they are nasty also. Giardiasis — popularly known as beaver fever [1] — is a parasitic disease caused by the flagellate protozoan Giardia lamblia ....
  8. #18
    Join Date
    Jan 2012
    Posts
    1,418
    Ma
    Kubota b2920
    Quote Originally Posted by studor View Post
    Nope, but we had issues in the past and after many rounds of trapping we ended up putting in a few devices to help eliminate the issue. Now we've got a pond where the level is constant, the trees / marsh area is not flooded and there are beavers. We used the PVC type devices as well as the long wire mesh devices they put on culverts. This eliminated, what had become an annoying cycle of waiting until there was a problem again, trapping, destroying the dam and doing it again. Now it takes none of our time and there's no issue.
    One caution on shooting, depending on the weapon you're using be very careful of ricochets of the water, if the angle of entry is low its amazing how far and fast the bullet can go. We found out the hard way shooting some turtles out of a pond, found holes in our trees on the other side (thankfully not in a neighbors house!)
  9. #19
    Gold Member mvwicker's Avatar
    Join Date
    Sep 2009
    Posts
    325
    St Louis, MO
    2007 New Holland TC34DA
    Here's some amateur beaver action video (rated G, natch, unless there's something really wrong with you) that you may want to watch with the sound low or muted ('cause the narrator and the music are pretty annoying):
    The most amazing beaver experience. [VIDEO]
  10. #20
    Super Member
    Join Date
    Apr 2002
    Posts
    9,936
    Northern Virginia
    Kubota's, John Deere's
    google coni-bear traps. Get two at least.
    I used sticks from the dam to create an alley way for the beaver to repair the hole I poked in the dam. They sense the flow, and go right into the trap.
    Sitting around at dusk in the woods waiting for a good shot is a waste of time and effort for me on these animals. Much easier to set and get the next day.
    Good luck.
    You may also see if your county animal control/enviromental people would declare them as "pests". That opened up free-hunting/trapping for me in my area.
Similar Threads
  1. Pesky Alders
    By keegs in forum Rural Living
    Last Post: 09-06-2011, 10:39 AM
  2. Out Pesky Swirl Marks !
    By Ductape in forum Customization
    Last Post: 06-04-2006, 11:10 PM
  3. Pesky Chain Saw
    By SteveV in forum Chainsaws
    Last Post: 04-07-2002, 02:10 PM
  4. Pesky Rye grass
    By Anonymous Poster in forum Rural Living
    Last Post: 03-29-2001, 08:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
