Results 1 to 10 of 10
  1. #1
    Silver Member Gordo 56's Avatar
    Join Date
    Mar 2011
    Posts
    199
    Park Forest, IL
    Kubota L3000 DT
    Default How One Man built his Pole Barn House
    How One Man Built His Pole Barn House.
    Posted on April 3, 2013 by Gordon Milligan
    How One Man built his Pole Barn House-p1030886-jpg
    Blake's 30x56x14ft high wall pole barn house.
    This is a post from my farm blog, I know a lot of people build these here on this site, so I thought I would share this here.
    One of my readers Blake who commented on the post I did about pole barn house told me he had just finished his pole barn house and he had put in a lot of things that I was planning to do. I wanted to see his place and emailed him to see if he wouldn't mind sharing some pictures of his build and answering some questions on the building process. He said he was happy to answer any questions I might have and would send me lots of pictures of his place. I knew others who are thinking about building their own pole barn house would be interested in these too, so I convinced him to let me do a post about his project. In this post we will go over the entire building process of Blake's house and get some questions answered so all of us will get a better understanding of what this all entails.
    Blake's house is built near the town of Many Louisiana by the Texas border in the middle of the state, and was built as a vacation home on a lake that Blake and his family use on the weekends and vacations. It is about a three-hour drive from his current home. Like most people who decide to build these types of homes he had a contractor build the outside and then he did all the rest of the work in his spare time. Blake said it took two years and it was only on the weekends. I also did it cash only, so that dictated the speed of the build as well.
    How One Man built his Pole Barn House-deck-done-3-jpg
    Front porch of Blake's home.
    When asked I asked him what he did for a living? He said "I am an MRI Technologist. I practiced full-time for 15 years then managed to weezle my way into the executive/ownership side of a multi site medical imaging company". He said he had "zero construction background, but have always been handy". When asked how long did you plan your home build? "I went thru several different options and pricing before deciding on a pole barn. I read a lot of post in the Garage Journal forum as well as others. Intensely planned for about 4 months before being completely confident" Blake said.
    "I think this is one of the easiest and quickest methods of construction. The most difficult part is constructing the shell, it must be square and plumb (no secret here)" Blake said. "I think someone with modest skills must research and must have (rent) the proper equipment or at least a tractor with a front end loader, forks, and an auger."
    Convincing his wife might have been the hardest part of the project. "The kids love the loft and spiral staircase. The wife was skeptical of the concept, but now thinks it is nicer than our main home and loves the rear deck, tongue and groove walls, solid granite counter tops in the kitchen, and old barn cypress cabinets (that are not yet complete)" Blake said.
    How One Man built his Pole Barn House-p1030888-jpg
    The garage is 30x16 and the living area is 30x40
    First Things First
    The first thing Blake did was get a permit for the building and do a perk test for the septic system. To prep the site He had to remove 8 trees and three old stumps before bringing in 20 loads of a sand/clay mix for the house pad?
    How One Man built his Pole Barn House-pb-028-jpg
    The poles were spaced 8ft apart on center and the part in the ground had a PVC sleeve over them, that helps keep the post from rotting or getting eaten by termites.
    Poles are 4 feet into the ground. The soil is very compact clay and we did not use any concrete around the post. Blake said. just a gravel base.
    How One Man built his Pole Barn House-build-1-17-jpg
    You can see in the above picture, were Blake used scissor trusses over the living area and regular trusses over the garage area. It still keeps the roof line the same on the outside.
    He used a 2x6 treated base board and 2x6 girts two feet on center, then did the framing for the windows and doors. After the contractor finished the outside frame is when Blake took over. чев had done a rough plan of the plumbing before construction was started, but that changed a little when I started putting them in the dirt Blake said.
    How One Man built his Pole Barn House-rough-plumbing-007-jpg
    Rough in Plumbing
    Plan where your bathrooms and kitchen will go before construction starts. You will need to know where your sinks, toilets, and washing machine will be so you know where to dig to put your sewer line. Having your drain lines, toilet drain and vent stacks in place and sticking up and caped so no dirt or cement gets in them is a must before the concrete is poured.
    "I put a few 3/4″ electrical conduit 90′s in the exterior wall portion of the concrete pad for future electrical runs if I need them, had the dirt pad treated for termites before concrete, and used wire mesh in the fibercrete slab" Blake said. "I only used a plastic vapor barrier, no need to insulate under the slab this far down south." Notice in the picture above the strings to show where Blake plans to put interior wall
    How One Man built his Pole Barn House-p1030362-jpg
    After the slab is poured
    Framing interior walls
    How One Man built his Pole Barn House-p1030900-jpg
    Spray foam insulation really stops all air infiltration and really makes the pole barn house more energy-efficient.
    After finishing the concrete pad Blake started framing the interior walls. He framed it as you would a regular stick built house. Another option for framing the outside walls would be the bookshelf method that uses even less lumber. After running all his electrical wiring he then had a contractor spray the foam insulation. He had open cell spray foam sprayed directly to the metal siding (3″) and metal roof 4″) which makes for a very efficient building. The foam also cuts the noise from rain to levels of a shingle roof Blake said. From here on out the building process is no different then building a regular home.
    How One Man built his Pole Barn House-loft-013-jpg
    Sleeping Loft
    Finishing interior walls
    How One Man built his Pole Barn House-pb-037-jpg
    In the kitchen area that will be mostly covered up with cabinets he used drywall.
    Having a good lighting plan before drywall goes up that includes knowing were all your lights, receptacles, and switches go before construction is started makes the whole project go much faster.
    He then used tongue and groove knotty pine siding on the rest of the walls.
    How One Man built his Pole Barn House-tng-1st-install-009-jpg
    He then used the same siding on the ceiling.
    How One Man built his Pole Barn House-box-beam-006-jpg
    Box beam to hide where the seam comes together on the ceiling
    Last but not least
    How One Man built his Pole Barn House-floor-done-002-jpg
    For the flooring Blake chose to go with tile for the kitchen and bathrooms and Laminate flooring for the living room, and everywhere else.
    spiril stair case.
    How One Man built his Pole Barn House-stairs-016-jpg
    He then put the spiral stair case for the sleeping loft in and trimmed the house out with knotty pine trim. Now all he has to do is finish up the kitchen cabinets, counter top and add appliances and he will be done.
    "The cost of the whole thing will be right at 80K after I get the cabinet doors back from the cabinet maker. This came out less than my estimate of 90k when I first started" Blake said.
    When I asked him if there was a chance to do things over again what would you do different? he said "Of course I would have gone a little bigger! I also would have spent more time in the planning stage with the window and door placements. The poles dictated where a few of my windows and doors had to be placed, this never occurred to me during planning. I ended up having to cut one post for the kitchen window and using long 2x12′s above and below the cut connecting the adjacent poles to reduce any structural issues. I also had to move another post over by 1 foot in order to fit my large living room window (went from 8ft on center to 9ft between those two poles). I had to actually leave one window out of the build in the living room area and had to choose sides of a pole that ended up right in the middle of my bedroom wall. These situations could have been accounted for if I had only realized it before hand and planned accordingly."
    Blakes ceiling fan
    How One Man built his Pole Barn House-box-beam-020-jpg
    What a great example of pole barn house that is maintenance free, and that I think will stand the test of time. I want to thank Blake for sharing this with us. I hope you all have learned something on how to build a pole barn house, and are a little more confident to take on your own project, I know I am. If you have any questions about the building process feel free to ask them here.
    To see more posts and photos of my farm, Milligan's Gander Hill Farm, A Beginning Farmer link to my farm blog at http://milligansganderhillfarm.wordpress.com/
  2. #2
    Platinum Member Dr Dave's Avatar
    Join Date
    Feb 2012
    Posts
    849
    sioux city, ia
    Oliver 1855, Case 1840, Cub 1550
    Default Re: How One Man built his Pole Barn House
    Nice looking home! From the inside, you would never know this was a pole building. Thanks for sharing.
    Dave
  3. #3
    Super Member
    Join Date
    Apr 2006
    Posts
    6,484
    Wise county Texas
    Kioti DK 35 now
    Quote Originally Posted by Dr Dave View Post
    Dave
    What Dave said!
    Dennis
    "Winter 2013 a majority of the country is setting new cold records, Colorado is setting new record HIGH's"
    "If at first you don't succeed, skydiving is not for you."
  4. #4
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    Dave
    I concur. I enjoyed the pictures. Thanks for posting.
    The PUPIL who does not surpass his Master, fails his Master.
  5. #5
    Elite Member coobie's Avatar
    Join Date
    Sep 2004
    Posts
    4,110
    S.Michigan
    Kubota RTV 900, JD 740,Kioti DK 40 with KL401 loader .
    Great thread,looks great and thanks for the story and pics.coobie
    Kioti DK40se hst cab with KL401 loader,Kubota RTV 900,John deere X740,Kioti 73 inch tiller.Ingersoll 4020 3pt,troy bilt tiller,Billy goat brush cutter.
  6. #6
    Join Date
    Dec 2009
    Posts
    81
    how much that spray foam cost ? i like that ideal !!
  7. #7
    Join Date
    Mar 2011
    Posts
    199
    Park Forest, IL
    Kubota L3000 DT
    Quote Originally Posted by peabody View Post
    I don't know how much it cost, I will have to ask Blake and get back to you.
  8. #8
    Join Date
    Mar 2011
    Posts
    199
    Park Forest, IL
    Kubota L3000 DT
    Blake said It cost 4300.00. He got 7 quotes with the high being 7000.00, he says it pays to shop around.
    I have added more pictures of this house on my web site for those that would like to see more pictures.
  9. #9
    Join Date
    Nov 2012
    Posts
    1,544
    mansfield,Il
    john deere
    How do they control the mess with spray on ? Beautiful place , love the ceiling and walls .
  10. #10
    Join Date
    Mar 2011
    Posts
    199
    Park Forest, IL
    Kubota L3000 DT
    Quote Originally Posted by kevin37b View Post
    I have seen videos of companies spraying the foam. The gun is similar to a paint spray gun and they have great control. It don't look like they have much of a mess. Thanks for your comment.
Similar Threads
  1. Pole Barn House
    By Gordo 56 in forum Rural Living
    Last Post: 07-13-2012, 02:19 PM
  2. Pole Barn/House
    By QRTRHRS in forum Rural Living
    Last Post: 08-04-2011, 03:23 PM
  3. Who's Built Their Own Pole Barn
    By Rumbles1960 in forum Build-It Yourself
    Last Post: 04-01-2010, 10:52 AM
  4. Ever built a Pole Barn?
    By holstein05 in forum Projects
    Last Post: 07-27-2006, 05:23 PM
  5. Pole Barn House?
    By willy1947 in forum Projects
    Last Post: 05-08-2004, 03:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
