NHmitch
We actually just bought 2 tons of Barley seed, and we are growing it as fodder for our animals, and it has to last us about a year. We looked into multiple options, and the first I considered was using IBC totes, and we then found that they would not fit in the space that I needed them to, so I bought 55 gallon poly drums. They can be completely sealed from moisture, and I have two cats living where they will be stored, so hopefully rodents will not be an issue. I am looking into the dry ice idea, to remove the air. Each 55 gallon barrel, cost $5 used. I purchased them from a John Deere Tractor dealer who had used them for other purposes, and sold the barrels after they had been cleaned.. People around us use them all the time for sap collection to produce maple syrup.
It was very difficult locating organic, non-treated seed, non-cooked seed that will germinate. I originally ordered 1 ton directly through the USDA service center near us, and the seed that they sent, came from Canada, and even though the seed was marked certified organic, and made it through Canadian and US customs, it was treated heavily with very strong germicide, and herbicide that was developed by Bayer Pharmaceuticals. The reason I found this out was after initially mixing it with our bleach water solution, my arm was coated with the treatment, and It resulted in a chemical burn on my right arm, from my hand, to my shoulder. It turned out that the seed, with the treatment on it, required a suit with a respirator to handle it, and even after planted it would not be safe for humans, or livestock to walk on for 5 weeks.
In short, be very, very careful when buying your seed, because we were promised that ours was untreated. It came directly from the USDA, and it was the exact opposite of what we had ordered, and it would have most likely killed our animals if it had been fed to them after our 8 day growing cycle.
