We have a retired travel trailer (28') on the ranch that is used for worker housing.
This is more of a worry to me. Worker/renters do not take as much care as the owner!
Mobile is not the problem, it is the construction. They do not burn slow and once started they are gone quick.
If a stove is properly installed with the right flue materials and floor protector, then the only danger compared to other forms of heat is that the operator has to open the door and load the wood and regulate the heat output. If you read up on the cat trains up above the actic circle (wagons on sleighs) they had wood and coal fired stoves in the "caboose" which is where they ate and slept and these were mobile. Granted, the risk of falling through weak spots in the ice may be greater than dying in a fire, but that was the way those guys lived.
Without a doubt, no shortcuts can be taken on the install of the stove or the flue, or else the prolonged exposure to heat will finally result in ignition of material that is within the clearance zone of the hot parts of the stove. If ones attention strays for a few minutes too long, the flue temperature will peg at close to 1500F (visibly glowing). This is one of the biggest risks when simple people do not understand the dangers of an untended stove.
A crazy idea I had at one time was to put together a wood burning boiler for outside and run the hot water line inside to a car radiator that came with a 12 V fan! Run the fan on a battery charger. You could even put a thermostat to control the fan.
I never got around to trying it.
