Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Silver Member MtHam's Avatar
    Join Date
    Mar 2010
    Posts
    139
    Northern California coastal hills
    Kabota B3030
    Default Wood Stove in Trailer
    We have a retired travel trailer (28') on the ranch that is used for worker housing. I am considering a small wood stove for heat, as we have an unlimited amount of small firewood (1-4" branches from our 'thin & release' work) available. Has anyone done this? What stove do you use? Any particular recommendations? Did you run the flue through a window, or straight up through the roof? Any suggestions or tips would be appreciated.
    Wood Stove in Trailer-trail1-jpg
    Kubota B3030, BH75 BH, LA403 FEL, Tiller, Mower, Box Scraper, Wallenstein FX65 Skidding Winch, BXM-32 Chipper/Shredder,
    Kubota 8kw genset, RTV900, 1983 TroyBuilt Horse tiller
    8 trailers-12' dump, 8' utility, 12' box, 25' box, 28'TTx2 (worker housing), 28' 5th wheel TT, ATV trailer
    Polaris RZR 800 SxS, Yamaha Kodiak 450 ATV, Yamaha TW200 MC
    6kw grid-tied solar PV system, DHW solar system, solar water pump, 18x36' solar heated swimming pool
    4 Stihl chainsaws, 45 acres forest and meadowland
  2. #2
    Veteran Member westcliffe01's Avatar
    Join Date
    May 2009
    Posts
    1,221
    SE MI
    Bobcat B200 TLB
    Default Re: Wood Stove in Trailer
    Not exactly the same situation, but my uncle and aunt in VA live in a "converted" trailer home, which has an addition on the South side and the whole thing has been roofed over and extra insulation added in the attic. A few years ago, my wife and I bought the smallest EPA rated wood stove, it was made by Century and Menards was running a fall special for $250 for the stove. The stove pipe and class A chimney cost more than the stove... I also had to get a ceiling "thimble" to provide the correct clearance to combustibles where we passes through the trailer roof. The flashing takes care of that interface where one intersects the main exterior roof, just the hole has to be cut to allow for 2" Min clearance to combustibles. We installed that stove in 2 days from start to finish.
    It has worked out great for my uncle and aunt. They burn about 1 cord per winter and still have their oil furnace as backup. You will have to do as we did, and build a proper floor protector. We welded up an angle iron frame, laid in 2 sheets of cement board, then tiled the top surface to provide both a thermal break and a fireproof surface around the stove, since small embers will fall out every now and then when loading wood. It also spreads the weight of the stove on the floor.
    For a travel trailer it is a little hard to imagine where you would put it. Because of the clearance requirements, it ideally needs to go right in the center somewhere where people can walk around it. You need to look at the clearance requirements to single wall, double wall (stove pipe) and the stove itself. In many cases the clearances may be 16". If the people managing the stove are not the brightest, you have to cover all the possibilities or your trailer will be going up in smoke. The question where to stage firewood will be another important point.
  3. #3
    Elite Member
    Join Date
    Jun 2012
    Posts
    3,801
    Waynesboro Va
    John Deere X310, JD LA 145
    I was a fireman for vol. fireman for 10 years, we saved a lot of houses but we NEVER saved a trailer. IMHO a wood stove in a trailer is a trailer fire waiting to happen. I advise against it.
  4. #4
    Join Date
    May 2009
    Posts
    1,221
    SE MI
    Bobcat B200 TLB
    If a stove is properly installed with the right flue materials and floor protector, then the only danger compared to other forms of heat is that the operator has to open the door and load the wood and regulate the heat output. If you read up on the cat trains up above the actic circle (wagons on sleighs) they had wood and coal fired stoves in the "caboose" which is where they ate and slept and these were mobile. Granted, the risk of falling through weak spots in the ice may be greater than dying in a fire, but that was the way those guys lived.
    Without a doubt, no shortcuts can be taken on the install of the stove or the flue, or else the prolonged exposure to heat will finally result in ignition of material that is within the clearance zone of the hot parts of the stove. If ones attention strays for a few minutes too long, the flue temperature will peg at close to 1500F (visibly glowing). This is one of the biggest risks when simple people do not understand the dangers of an untended stove.
  5. #5
    Platinum Member KYErik's Avatar
    Join Date
    Dec 2005
    Posts
    839
    South central IL
    1980 JD 2840, 1963 Ford 4000, 1943 Case SC, Case 530CK backhoe
    If the trailer is pretty air tight, you should get a stove with an air intake tube so that it can suck combustion air from the outside rather than inside. The downside is that you will have to cut an extra hole for this air intake.
    "Attitudes are contagious; is yours worth catching?"
  6. #6
    Elite Member
    Join Date
    Jun 2012
    Posts
    3,801
    Waynesboro Va
    Mobile is not the problem, it is the construction. They do not burn slow and once started they are gone quick.
  7. #7
    Veteran Member MacLawn's Avatar
    Join Date
    Aug 2007
    Posts
    1,346
    Red Clay Country, GA & Mississippi Prarie
    JD 2210
    I'm with old Ed the firefighter. Too dangerous methinks, let them boys be a bit cool.
    "He's pinned under an outcropping of rock. Lucky for him, the rock kept the dirt from burying him alive". Dirt, it's nothing but dirt, I tell ye...
    If idiots could fly, this place would be an airport.
    "I wouldn't want to be within 400 or 500 yards of one of them newfangled nuclear bombs when it went off!" WW1 Vet...
  8. #8
    Join Date
    May 2005
    Posts
    2,069
    N. E. Florida
    I lived in an old (1976) doublewide 10 years ago.
    I put in a HF wood stove to save on heat.
    I put down a pad from concrete blocks, set it away from the wall, made a sheet metal insert for the window behind it to run the flu pipe out and up.
    Turned all the way down that thing screamed! I even put a box fan to circulate the heat.
    I tried it for a couple weeks only burning it when I was home and awake. It was still scarry dangerous. I took it back out and sold the stove!
    I would not trust employees manage a stove like that.
  9. #9
    Join Date
    May 2009
    Posts
    1,221
    SE MI
    Bobcat B200 TLB
    So how do y'all feel about wood stoves in boats then ? Perhaps a diesel fired stove would be safer than wood ? At least the operation would be more predictable and less susceptible to "operator error".
    Wood Stove in Trailer-home_4_pics-jpg
    Here is a Diesel fired marine heater that has a cooking surface
    Wood Stove in Trailer-00lof-jpg
    Sold here for $764 Dickinson 00-LOF Diesel Lofoten Floor Mount Heater - Diesel Fireplace
  10. #10
    Platinum Member RoMad's Avatar
    Join Date
    Oct 2010
    Posts
    562
    Lecanto Florida
    Kubota L3710
    Whether you use the stove or not make sure they have a working fire detector. I had a lady in an older single wide mobile home burn it down with a grease fire. She fell asleep while cooking tater tots in her fry baby. The trailer burned down quickly. She was fine.
    I would not be afraid to put a small stove in a travel trailer as long as you set it up properly.
Similar Threads
  1. Burn wood pellets in regular wood stove?
    By sixdogs in forum Rural Living
    Last Post: 10-08-2012, 04:25 AM
  2. Wood stove
    By sherpa in forum Rural Living
    Last Post: 12-11-2011, 01:09 PM
  3. Wood Stove Fan?
    By B8FISH in forum Rural Living
    Last Post: 09-16-2011, 11:12 PM
  4. wood stove & pellet stove
    By roermo in forum Projects
    Last Post: 04-06-2010, 08:07 PM
  5. pellet stove vs. wood stove
    By Unregistered2013 in forum Rural Living
    Last Post: 09-04-2007, 10:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
