mikehaugen
Elite Member
Well I know there are a lot of tou ham operators and others out there that know about radio waves and such. I have a tv antenna that isn't being used anymore because of the dish. I would like to utilize it for fm reception. There is a receiver in the house and in the garage that need better reception.
For whatever reason there are 2 different types of antennas up there (see pic) pointed east. I live about 80-90 miles west of Chicago and about 40 miles south of Rockford, both of which transmit. I would prefer Chicago, and that is where the antenna is pointed it seems. The two antennas feed into some kind of box, which then has a coaxial cable running down the tower. I can split that cable and run coax to both places using rg6. The question I have is how do I connect it? The receiver in garage has both a 75 and 300 ohm input. I see 300 ohm adapters, but do I really need that since I have the 300 ohm input? I don't see any just straight coax adapters to wire to the screw terminals, so how do I wire into those unless I use the transformer?
Also, what do you suggest with the antennas? Keep using them both, or just one? Airwave transmission is quite confusing and what I am trying to do seems pretty simple. Thanks for any suggestions.
