EddieWalker
Epic Contributor
When I built my house, it was mostly a workshop with a living area attached to it and a lot of plans that I no longer have any interest in perusing. Along the side of my shop I built an area that I've been using for storage with a porch area in front of it that was only 4 feet deep. I also had a very limited budget to build the it, so I went cheap on my exterior siding. I used Hardie 4x8 panels, which I've regretted, and come to hate. I love Hardie lap siding and I'm in the process of covering the existing Hardie with Zip siding, and then Hardie Lap siding.
In the picture, you can see how ugly the siding looks, and also how small the porch area is. All that porch did was hold water at the base of the wall. Totally useless.
Part of the changes is relocating all the utilities in that area. I have a 100 amp power line coming out of my attic area above the storage room, down the wall and then under ground to an RV pad and a shed. That had to me moved into the wall so I could put a window where that conduit is.
Then I ran new water lines, a drain line with vent, and power through the room. I also added two outdoor spickets so we can water the garden easier, and also fill the chickens water bowls. Everything is done with PEX and copper at the threaded ends. I like to use copper where I will attach valves because of how durable it is and how solid I can attach it to the studs.
