Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Elite Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    2,826
    central Iowa
    JD 2720
    Default Oily rags
    I've always been told bu various wood workers to soak your oily rags in water to prevent them from spontaneous combustion. But nobody ever told me what to do next.
    I have about a dozen rags and 2 pair of disposable gloves, all soaked with Boiled Linseed Oil, soaking in 2 gallons of water. All this is in a tin bucket with a fairly tight lid.
    Today is garbage-eve and I need to make room for more rags in the tin can.
    Is it safe to toss the rags into the trash now that they have been soaking in water? What about the water? I don't think (?) I want to dump it down the floor drain, it dumps into the house sump pump. I don't thing (?) I want it going into my septic tank.
    What is the smart thing to do?
    Oily rags-oily-rags-jpg
    HAVE FUN
    Life is easier when you plow around the stumps.
    2720
  2. #2
    Veteran Member KennyG's Avatar
    Join Date
    Jan 2011
    Posts
    2,152
    SW Michigan
    John Deere 2320
    Default Re: Oily rags
    All the official instructions are going to tell you to keep them in a fireproof container and then take them to a licensed hazardous disposal site. About 1% of us are actually going to do this.
    I don't even bother with the water. I collect them in a metal container and when I'm done for the day, I burn them, either in a burn pit or my wood stove.
  3. #3
    Platinum Member Snowback's Avatar
    Join Date
    May 2012
    Posts
    541
    Houston TX
    Mahindra 2538
    Quote Originally Posted by bigtiller View Post
    Perhaps just spread/lay the rags out on the driveway till morning? They usually only combust when all stacked together and where they can generate internal heat. As to the water, you can just use it to water the weeds you may not want on your drive or walkways...
    Good luck and stay safe!
  4. #4
    Elite Member RalphVa's Avatar
    Join Date
    Dec 2003
    Posts
    4,521
    Charlottesville, VA, USA
    JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
    I usually drape mine around the edge of the trash can. Then throw them in when I take it out to the cul-de-sac.
    Ralph
    The natural gardener
    God's original intent
  5. #5
    Super Star Member 2LaneCruzer's Avatar
    Join Date
    Nov 2011
    Posts
    10,885
    Oklahoma
    John Deere LX172
    I have a wire basket that I put my stuff in; the basket remains outside where it eventually off gasses and dries out. After an appropriate time...read "whenever they dry out and I think about it" I put the stuff in the garbage. Fortunately, I never use Linseed oil.
    Have Wings, Will Travel.
  6. #6
    Join Date
    Nov 2012
    Posts
    104
    Floyds Knobs, IN
    kubota B7100hst Branson 4520r Massey Ferguson 135 diesel
    Quote Originally Posted by KennyG View Post
    Totally agree. Just burn them in a metal bucket.
  7. #7
    Join Date
    Feb 2011
    Posts
    756
    Parish NY
    555DTC Farmall 200
    Yep in the summer in the burn pit, in the winter wood stove.
  8. #8
    Super Member
    Join Date
    Jul 2009
    Posts
    6,945
    SW WA
    Kubota BX2360
    I don't want them hot in a can, so I hang them in the open air until they are dry, then into the garbage. It is the drying process that creates heat.
    Bruce
  9. #9
    Veteran Member oldballs's Avatar
    Join Date
    Dec 2009
    Posts
    2,306
    Kansas...USA
    Kubota B2620 , Case 448
    I wrap them inside a plastic fertilizer bag and set them beside the burn pile which is inside a cool, damp part of the back hedge. They will be handy when the pile is ready to burn.
    Kubota B2620 HST (2012) Case 448(1983)
  10. #10
    Gold Member MF283's Avatar
    Join Date
    May 2009
    Posts
    497
    Lebanon, TN
    JD 5303 JD 920M JD550XUV Gator
    Yep, cheap fire starters
    Haven't seen to many tractors i didn't like, just partial to Deeres.
Similar Threads
  1. Oily rag disposal
    By JDgreen227 in forum Safety
    Last Post: 01-23-2012, 09:44 AM
  2. What do you do with your greasy shop rags?
    By charlz in forum Owning/Operating
    Last Post: 03-02-2009, 01:48 AM
  3. spontanious combustion of oily rags
    By Soundguy in forum Oil, Fuel & Lubricants
    Last Post: 01-25-2006, 09:15 PM
  4. Rags to Riches: Eyewitness
    By DAP in forum Related Topics
    Last Post: 06-11-2004, 03:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2016 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
