Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #471
as posted, this thread starts off with the settings... AT&T ZTE Mobley USB Tethering ASUS Router and probably others!
hook ethernet cable between asus using one of the lan ports , and other into lan on computer/laptop.
use a usb cable from the Mobley to the usb on the asus
use a browser to log into the asus with it's address,,, maybe 192.68.29.1 (which was the asus label)
follow these screenshots for the USB tethering settings:
then i had to pull my ethernet cable, and reboot both the mobley and asus,
it takes quite a few minutes for them to reboot and find each other,
then try logging in with the browser over wifi.... and you should see
everything connected, and the mobley listed as it's 3g dongle
My Asus AC1900 RT-N66U DARK KNIGHT screens look quite different than that
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #472
I wonder if anyone at ATT marketing had a clue what was going to happen when they made this offer? And did any manufacture of these mobile devices have a clue how this was going to "go viral"? Apparently not on either count.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #473
That's not correct. Weather very definitely does affect all radio transmissions, whether point to point on the earth or satellite to earth. There are entire textbooks written about the subject.
There are a lot of variables, including frequency and the weather itself, but the effects vary from very minor to very dramatic.
I guess I should have clarified by not as drastically. A well put together system should have very minor difference due to weather. A hard rain will completely take out satellite internet.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #474
And for anyone looking another solution the Gl Ar150 router
Amazon.com: GLI Mini Travel Router GL-AR15 with 2dbi external antenna, WiFi Converter, OpenWrt Pre-installed, Repeater Bridge, 15Mbps High Performance, OpenVPN, Tor Compatible, Programmable IoT Gateway: Computers & Accessories
at about 1/3 the cost.
For me I wasn't interested in the wifi feature of the modem compared to the Ethernet connection. It was very easy to set up and works well.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #475
Do you have to use the USB 3.0 or will the USB 2.0 work on the router?
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #476
Should be downward compatible
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #477
May have got a promotion!!
It is such a competitive environment now. T-Mobile keeps taking share from the big players. Take a look at their 1Q results.
Data is being commoditized at an ever increasing rate and it's a trade off for the big players on how quickly they adapt.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #478
A quick blip of availability at the BestBuy in Flint, MI. I had them in my cart, but a couple hours later when I called my local store (desperate for a store-to-store transfer) they said they did NOT have them in stock.
Perhaps they were there, and someone checked out while I was still F-ing around.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #479
This is interesting: and troubling.
looks like a lawsuit was filed in 2016 and then a second pdf is dated January 25 2017 that includes ATT and ZTE sprint and 20 others selling the ZTE Mobley and other versions over some of the tech....
wonder whether this has anything to do with availability?
[PDF]View Complaint - RPX Search
looks like Cellular Communications Equipment is the plaintiff
Found another site that lists the defendants and some have a (terminated) notation next to them ATT and ZTE are both marked
this has been worked out at least for ATT/ZTE Mobleys...?
also noticed the newest docket update was 5/10/2017
Looks like Apple is next.
ZTE also was fined almost $900000000 for selling phones to Iran.
[PDF]View Complaint - RPX Searchhttp://www.nbcnews.com/card/chinas-zte-will-pay-record-900m-fines-selling-phones-iran-n730086
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #480
Oops..
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
1998 Volvo VNL64T Sleeper Truck (A52384)
1998 Volvo VNL64T...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
44in Tooth Excavator Bucket (A51691)
44in Tooth...
2014 Buick Lacrosse (A52384)
2014 Buick...
