I'm having a hard time figuring this out.
I have a 12' x 18' well house with a 5 pitch roof.
The structure has a single 2' x 3' double pane window.
Roof rafters have 6" of open cell foam.
Walls have 3.5" of closed cell.
6" slab on grade has 2" of closed cell on top of it.
Well head is inside structure, coming up through concrete and feeds a 100 gallon galvanized (non-bladder) pressure tank (through a few feet of pipe with pressure switch).
I have a 500 watt, 220v heater for the structure, connected to an Ecobee thermostat (so I can monitor and record the inside and outside temp, as well as control the heater).
Now that it's cold here in NY (this is the first season with this setup), I'm surprised at how much energy it is taking to maintain 45* F inside this structure.
I've attached the data -- outside temp just above 30*F, setpoint at 45, looks like about 50% on/off.
I'm trying to figure out where the heat loss is and the only thing I can come up with (other than simply insufficient insulation, which would be surprising), is the pressure tank and piping.
I think the water temp is between 40 and 45.
Could the tank be the culprit -- sapping the heat?
If so, should I insulate the tank? Wouldn't that be weird considering the heat source (other than the well water's temperature) would be coming from outside the insulated tank?
Thank you,
Joe
Thank you,
Joe
