srs
I got into a discussion with some friends concerning lightning protection for metal pole barns. As expected a few opinions were given whether one should have some type of lightning rod, grounding, etc. Here are some conclusions as to what was recommended. By the way the building is a Morton metal pole building with a standard cupola on top with a Morton weathervane. The building will eventually have water supplied to it and a 100 amp subpanel box run from the home.
Some people said:
(A) don't add any protection,
(B) one person said add lightning rods,
(C) and one person said to ground each corner of the metal building with copper wire and an 8' grounding rod.
(A) The reason for not adding any protection is the odds are the building will not get struck by lightning
(B) The reason for adding protection with lightning rods is if struck it will send (hopefully) all electric directly into the ground, but with lightning rods (I thought) it would attract lightning.
(C) The reason for grounding each corner of the building is that if struck the electrical discharge will dissipate safely (breakup, lose energy) and send the current into the ground. I kinda like this thought, but I have no idea if this is true or not.
Anybody have some good thoughts here? Inspector 507???
