Medium brush fire water rig ideas and questions
/ Medium brush fire water rig ideas and questions #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
The Help with Brush Fire Water Rig thread has me thinking of our situation, we frequently have fairly large bonfires "out back" (in the middle of a grassy field) and I am looking to make a "water rig" for next year in case one gets out of control and needs containment.
Raw materials on hand:
  • 2" trash pump
  • 25' of 2" layflat line
  • ~8 feet of suction line
  • 35 gallon drum mounted in a cradle on a "garden cart" (has a 3/4" pipe out the bottom of the drum)
  • 3500# trailer axle on a trailer that will be scrapped soon (popup frame that someone tried to make into a flatbed)
  • Toro Workman 2100 (rated to carry ~1200# in the 5'x4' bed or tow the same amount)
  • Couple of tractors (see the list of the left), all of which could tow 2500# without much fuss
  • 1980s vintage Yamaha electric golf cart
  • Stream with a small pond ~500' from the fire spot (~2' deep and 10'x8' for most of the summer)
I am debating which of the following setups would be better:
  1. Use the axle, the pump and a 300 gallon tote (would have to buy) to make a water trailer with a mounted pump
  2. Use 2-3 of 55 gallon drums (can get for free) to make a skid that will fit into the back of the Toro and connect the drums in series to the pump
  3. Put 12v pump onto the existing 35 gallon drum
My thoughts on the three options:
  • Option 1:
    Upsides: Can unload a lot of water in a hurry, just hitch and go
    Downsides: Cant tow the trailer with the Toro or a golf cart when full (have to pull behind one of the tractors), filling partway will cause much sloshing.
  • Option 2:
    Upsides: Can unload a lot of water in a hurry, very mobile
    Downsides: Will be a pain to load and unload, will restrict what can be done with the Toro when it is in the bed, not sure I want to leave that much weight on it frequently, much less water than Option
  • Option 3:
    Upsides: Can move with anything, small
    Downsides: Not much water in a emergency situation, will be slow to load and unload (compared to the 2" trash pump)
My aim is to be able to wet down anything that comes loose and blows off or if the fire starts to spread in the grass.
Once one of our bonfires starts, its not worth trying to knock it down, would take a couple thousand gallons of water and someone who knows what they are doing, so I am just trying to keep it contained in a SHTF scenario.
Anyone care to weigh in?
Thanks
Aaron Z
/ Medium brush fire water rig ideas and questions #2
I would prefer a dedicated old pick-up to hold your tank, and pump set up. But with your options I would go with the tank on a trailer. and have your tractor hooked to it ready to move. At least 1 300 gal tote.
The problems I see is that I dont think trash pumps are designed to develop much pressure, unlike a 5hp Honda High Pressure "fire pump".
Also your 2" discharge line is going to be a bear to handle when full of water. The fire men on my land last summer were using 1" while I was killing myself dragging around 1-1/2" line.
/ Medium brush fire water rig ideas and questions #3
I would keep your trash pump at the pond to re-fill your tanks in a hurry, and invest in a Honda high pressure pump to run your spray line. I dont remember what mine cost since I bought it 5 years ago, but it wasnt too much.
/ Medium brush fire water rig ideas and questions #4
In addition to the water setup, I would also turn the ground around the burn area so there is no grass close enough to ignite with the heat from the fire.
/ Medium brush fire water rig ideas and questions #5
How much are you thinking of spending? I often see used, working fire trucks on CL for dirt cheap. Seems like it would save you a lot of troube and it would be way cool!
/ Medium brush fire water rig ideas and questions #6
Without baffles in tanks you're not going to be able to carry much water for a fast mobile "defense" & carry bulk water fast is next to impossible without heavy trucks, so I'd consider:-
- Your trash pump is probably only suitable for bulk refilling, as they usually aren't self priming nor develop sufficient pressure for much use in firefighting (Bush fires & more so grass fires which are relatively fast moving require high pressure for misting/cooling/smothering for effective quick "knock downs" - bulk "dumping" of water doesn't cover enough ground fast enough, is largely ineffective for quick containment, often making the situation worse dispacing embers around &
lower pressure can place you uncomfortably close/at higher risk nearer to the fire
- 2" layflat is heavy & cumbersome to move quickly without extra hands around when pressurised & if it's polythene adapt to kink, puncture, rupture or burn at the most critical time (canvas fire fighting self percolating hoses overcome these shortcomings but are too expensive)
- Consider purchasing a self priming high pressure fire pump & set up with two 30'+ x1" heavy duty fire hoses with fire nozzles , the fire pump can be self powered by a reliable 5hp engine, or mounted directly on the PTO or PTO shaft driven, even or Hyd driven. And fit the suction hose with a non-return/foot valve (it makes for quick priming & change over between water source like drums
- Strategically placing "clusters" of 3-4 x 55gal water drums around the radius of your bonfire site; your new 30'x 1" firefighting hoses & fire pump will provide min. 45' radius coverage (allowing 30' of hose + 15' effective water pressure from the fire nozzel) the drum clusters need to be only @ c.90' spacings
- Use the Toro, if it's your most nimble/fastest unit to carry the fire hoses/pump (assuming it's self powered) around between drum clusters & have it set up ready to provided water at a drum cluster from the outset of lighting your bonfire
- Fit the 12V pump to the 35gal cart & tow with one of your tractors which provides a mobile waster source outside of the drum clusters
- Cultivate/grade to bare ground around the burn pile & for c10'+ around each of your drum cluster as defensive "safe" shelters, & have long handed shovels on hand (dirt will stop/slow fires almost as good as water)
As volunteer Rural Fire Fighter for more years than I care to recall, controlling bush/grass fires is all about preparation/planning so everyone knows their task & risk, keeping a level head under pressure & fast mobility. Bush/Grass fires move extremely quickly so having high presure water on demand & multlple water sources located close by are more critical than any single bulk water source as any hoses can only reach so far & if you're forced to retreat to refill without any other effective defense remaining at the fireground it's game over because you've now going backwards.........you may be able to adequately defend a house from a bush fire front with timely well placed use of a c.200gals + foam additives static source, but chasing a bush/grass fire across open ground is a totally different ball game...
Attached are photo's which may be of interest, these are some of the smaller high pressure pump set ups we use on the farms (supplementary to the self powered fire pumps) shaft driven PTO , direct PTO mount & Hydraulic (these last two are small high pressure spray rig pumps which with foam injected at the nozzle make for excellent fire suppression) :--
/ Medium brush fire water rig ideas and questions #7
  • 2" trash pump
  • Option 1:
  • Option 2:
  • Option 3:
Thanks
Aaron Z
* 2" trash pump, 25' 2" flat hose and 8' suction hose - use to refill the tanks on the fire trucks from your creek, if they have to respond. Have mounted to old golf cart. Run 2" PVC pipe with strainer from creek to where you can get to with the "Yamaha Golf Cart rolling portable pumping refill unit". To keep from getting "stuck", run a 2" PVC pipe with strainer and foot valve from the creek to where you can get to with the cart. MOW and clear a safety zone with your lawn tractor around the "dry hydrant" site so you don't burn up your golf cart. Look up "dry hydrant" on the net.
35 and 55 gallon drums. Cut the tops off, paint red, and mount three 2.5 gallon galvinized water buckets on hooks to each barrel, covered by a lid. Place wherever you want these. In colonial times, many fires were fought from "rain barrels". If the drums are plastic instead of steel drums, better yet.
3500# trailer axle - scrap or use to keep a "water buffalo" with 300 GL tank near the house for water supply during fire season. Have a hookup on the tank to hook into the trash pump to refill your - - -
Toro Workman 2100 with sprayer unit mounted in the bed. Forget the steel drums on the Workman. Get a nice little poly water tank with a large electric, small Honda WX10, or Honda WX15 pump and at least 100' of 3/4 Ag spray hose with garden hose nozzle and shutoff. Those plastic tanks are not that expensive. Check out your nearest tractor supply, fleet and farm, or farm supply store. Sprayer units are available from Fimco, Northern Tool & Supply and Graingers, but you can build your own. I would go 50-75 gallons on the Toro, or you could have some equipment breakage issues from excessive weight. The Toro would be your most effective intial attack spot fire sprayer unit, and could "spray and roll" at the same time.
Stream - useful not only for water supply, but as a natural barrier to stop a wildfire or to prescribe burn the pasture from. A trail alongside the stream would be beautiful.
Tractors - Get a "bush hog" and keep your pastures cut down during the summer. This will reduce flame lengths if you get a fire, reduce ticks from Lyme disease, and keep down weeds and brush. Maintain fire trails through your property with the tractors and mowers, as hiking trails, fire trails to prescribe burn from and for fire defense, snowmobile trails, etc.
You could also take those steel drums and trailer and make a big BBQ trailer and smoker to cook over during your overnight bon fires. Now Thats what I call "fire management". A good oak fire pit and some steaks.
The BEST thing would be to finish mow a 12' fire break with a JD lawn tractor back 100' from your bon fire area, burn out the grass on a quiet Spring morning, and not have to worry about it until it grows back. "Burned" grass or new "green" grass will not "burn". That is what I do near my backyard fire pit.
Unless you have TALL grass, or burn on a dry windy day, 6-10 GPM or even a garden hose from a small pump should be able to suppress any spot fires. Don't burn when the NY Forest Rangers or USFS forecast a Red Flag Warning or HIGH fire danger. There is always the option of not lighting the match. Of course, night burns should be safer, but watch out for forecasted winds the next day that could send your fire across the next hill.
I looked up that area on the Internet. Beautiful!
SC
Thanks for the ideas all, attached is a layout of how the place is laid out, we already keep the field around the burn pits mowed to 4-6" tall. Will look at the various options on water rigs and report back.
Aaron Z
/ Medium brush fire water rig ideas and questions #9
My starting point would be prevention.
- Smaller piles - We can not have that big of piles here without special permits. We're limited to 4'x4'
- Scrape a buffer zone down to dirt around the pits. We can not have piles that big here, but I still scrape 10' or so out to dirt.
- Mow a larger perimeter as short as possible. Remember, a fire in dry grass or other light flashy fuels can easily outrun a person. Firefighters have died or been seriously burned when conditions changed and a fire outran them.4-6" tall dry grass can burn really fast...
- Consider discing or scraping a fire break around the fence-line or perimeter of the field. Down to dirt...
- Always make sure the fire is attended to until it is dead out.
- We always fight fire with 1.5" hose, whether on a pump and roll, or when laying hose out to a fire. 1" is for mop-up. For just one person though, 25' of 1" would probably be all you could manage.
- Check with your local FD. They know local conditions, and may be able to give you good pointers.
- A phone. Call for help before it becomes a major problem. I'd rather get canceled in route, or just have a little mop-up than to have the doo doo hit the fan and have extended rural response times...
I would think about making the trailer in to a water buffalo. The water buffalo with a pump would be nice if you had a spot fire. It seems like something that would just be handy to have around in general. Of course, I also like the used fire engine idea too :D
A quick douse with a bucket of water will stop a lot of little spot fires too.
With three tractors available, I would consider having one or two with a bucket load of dirt.
/ Medium brush fire water rig ideas and questions #11
Thanks for the picture
/ Medium brush fire water rig ideas and questions #12
Probably the cheapest and easiest route would be to look for a old used hydroseeder. Look for a plastic tank recirculating type to save on weight. Used ones are a fraction of the cost of new. Some are trailer and some are skid mount. Sizes start around 100gal and can go upto 4000gal. The small 100gal skid mounted machines can be carried in a golf cart and at 8lb per gal you can figure your needs for the larger machines. Advantages are that it is a fully self contained unit, complete with water pump and discharge hose. Different types of nozzels can be interchanged according to needs, fan types for just wetting down close areas, or 100ft long distance nozzels for large streams of water. These machines can also be used for mixing ice control solutions for treating driveways and dust control by using approved dust control products. Might as well have something you can make money with when you aint fighting fires.
/ Medium brush fire water rig ideas and questions #13
I like that idea the best.
Here is a reputable used fire equipment that has a "bargain" section featuring apparatus that cost less than $10,000:
Firetec Home Page
/ Medium brush fire water rig ideas and questions #14
Not too far from you is the Finger Lakes National Forest ranger station.
Pay them a visit and ask them to show you what they are using for grass, brush and forest fires. Some places need the big 1.5" hose, but we extinguish 90% of the fires with a 3/4" hardline on a reel.
Take a look at the tools, swatters, fire rakes, etc. In many areas in the Eastern Hardwood Forest region, they use backpack leaf blowers to construct fire breaks through the leaves.
Also might check out a NY State forestry station.
Up here, the US Fish & Wildlife Service fire program uses Polaris Ranger 6x6 UTV's with a tank, Honda WX15 pump and small hose on a reel.
Here is a similar unit that is used by a nature conservancy in Wisconsin for holding their fire breaks on prescribed burns.
If you cannot extinguish a spot fire with the Workman, 60 gallon plastic tank, pump and 100' of 3/4" Ag hose with garden hose nozzle, you need to have the Fire Department out there, anyway.
As someone already mentioned, prevention is "key", and I stress the "right" conditions - not just the night of the bonfire, but the extended forecast as well. If the relative humidity is in the thirties, you can get spotting, If the RH is in the 20's, expect to be needing the fire department when the wind comes up.
This is not the forum to try to make you a "burn boss", but take a look at the parameters, below, for burning and remember the 40-60 rule - relative humidity at or above 40% and temperatures at or below 60 degrees and you should be able to handle anything with a garden hose off a sprayer in your neck of the woods (this does not pertain to California, Australia, Pitch pine of east coast, etc.)
http://okfire.mesonet.org/sub_info/OK-FIRE Basics for PRESCRIBED BURNING.pdf
The burn article I saw mentioned that spot fires can occur from a large pile, 500 feet away.
When things "green up" in the Spring, the danger is lessened.
Good luck and send photos of the site.
SC
Got a couple of pictures at dusk tonight:
Current water machine:
Pictures of the firepits, the woods and the stream:
Sorry for the picture quality, my phone camera didnt like the lack of light.
Aaron Z
HUSQVARNA RIDING...
KUBOTA M8540D TRACTOR (A60430)
KUBOTA M8540D...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A60429)
2021 CATERPILLAR...
2021 CATERPILLAR 259D3 SKID STEER (A60429)
2021 CATERPILLAR...
Crown SP3550H-30 Stand-On Electric Forklift (A59228)
Crown SP3550H-30...
UNUSED FUTURE FT-GB200-79"X71 1/2"-1" STEEL PLATE (A60432)
UNUSED FUTURE...
