Ball joint interchange between ford and international help??
   / Ball joint interchange between ford and international help?? #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Working on this IH 300, ball joints/drag link ends are $50 each:confused2:
Looking for a suitable (and affordable) solution, the ones that fit most of the common fords of the era (N-series, 600/601 and 800/801 series and more)......Seem to have the same 11/16" x 18TPI threads. And look darn similar. But no one lists the dimensions of the taper part and castle nut.
So has anyone been down this road?? Will they interchange?? Or is there something else that will work and not cost $50 per joint???
I'll try to make some phone calls and get this cleared up if no one on here knows.
Farmall Front Drag Link End for Farmall 300,330,340,460 (363160R91)
Ford Steering NAA3270A Drag Link End, Front, Greasable
Or....if anyone has one of the mentioned ford joints laying around, if they could take a measurment of the taper part. Diameter at the big end, small end, and taper length, I'll measure my old ones and compare??
Sucks that $50 per joint for the IH. IF the Ford ones will work, I can get all 4 for that price.
Maybe I found my answer??
Steering / Front Axle
These guys list the same $13 part as fitting the fords, and internationals. Which begs the question, why do most other places list them separate, and the IH joint costing 4x's more.
   / Ball joint interchange between ford and international help?? #4
I have seen it both ways. Ie seperat elistings, and then only machine specific listings.
hope they have the correct dimensions there for ya.
I am hoping they are correct too.
I am sure the threads are correct. The taper part is what I am unsure about. IF the threads are correct, but it dont fit in the spindle, it does no good.
Do you happen to have, or would be able to measure the tapered hole on the spindle in one of the fords?? Big end, Small end, and thickness?? Just to comfirm??
IT is very strange that all-state-ag-parts list them as the same, but places like YTmag are different and the IH part is 4x's the cost.
I'll go measure mine now.
   / Ball joint interchange between ford and international help?? #6
when i get back tot he farm I'l pop one off.
Here is what mine measure that I need the joints to fit.
The big end of the taper is hard to measure, but pretty close...
   / Ball joint interchange between ford and international help?? #8
hmm....
   / Ball joint interchange between ford and international help?? #10
Last joint i had off was onmyh rowcrops mind you, and an offset.. and they were pretty big.....
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
TMA (A49461)
TMA (A49461)
FAKE (A52472)
FAKE (A52472)
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
2013 Infiniti M37 Sedan (A53424)
2013 Infiniti M37...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
