Kioti DK45SE box blade/carry-all/trailer hitch/counterweight/top n tilt VIDEO
   / Kioti DK45SE box blade/carry-all/trailer hitch/counterweight/top n tilt VIDEO #1
oercheron
Aldergrove, BC
2 Kioti, 2 John Deere. None wore out yet but the '49 ain't used that much anymore
https://www.youtube.com/watch?v=_8GWYSkXwIk
A conglomeration of ideas mostly taken from this board.Thanks to all for contributing!
My tractor happens to be a Kioti DK45SE. These mods really are not model specific however, and could be used on just about any tractor that carries a box blade.
   / Kioti DK45SE box blade/carry-all/trailer hitch/counterweight/top n tilt VIDEO #2
very nice
   / Kioti DK45SE box blade/carry-all/trailer hitch/counterweight/top n tilt VIDEO #3
nice job with that. now all it needs is a fancy paint job to prevent rust and look purddy...
Well I got the upper rack painted Kioti gray, and some more counter weight added (found a chunk of railroad rail) so just the orange left to do now...
   / Kioti DK45SE box blade/carry-all/trailer hitch/counterweight/top n tilt VIDEO #5
Grader boxes are handy, I've got so much on mine that i need to get another one to use for a grader box.
Your wish is my command... I also welded on a piece of railroad track across the back for more ballast.
   / Kioti DK45SE box blade/carry-all/trailer hitch/counterweight/top n tilt VIDEO #7
Fine job, paint job really polishes it off nicely. What is that little white container in the tray toward the back? And what size is it and what do u think it weighs?
The white container is a bubble level, the large RV type that can be read from a distance. You can see it better in the video
The box blade is 5' 6" and I think it is getting close to 1000 lbs now with all the extra ballast.
   / Kioti DK45SE box blade/carry-all/trailer hitch/counterweight/top n tilt VIDEO #9
A level was a brilliant idea. I'm surprised 5 1/2 feet covers the back of that tractor I would've thought it would've had to been at least six. Probably about the perfect size though Ill bet it's really nice when you're moving around in the woods not having it stick out too far. I went with the six footer five & 1/2 was special order on my CT 225 and it's about as much is it can handle with all the scrapers all the way down. I can stop the tractor with it if I get in to some hard pack. Again nice job and thanks for sharing.
   / Kioti DK45SE box blade/carry-all/trailer hitch/counterweight/top n tilt VIDEO #10
Sweet!!
:thumbsup:
Kubota Salt-Spreader (A52384)
Kubota...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53472)
Neckover GL24-2-7K...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A51572)
1998 Dorsey...
2021 Caterpillar 299D3XE Track Loader (A53342)
2021 Caterpillar...
2023 John Deere RD40F Draper Head (A53342)
2023 John Deere...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
