Results 1 to 6 of 6
  1. #1
    Platinum Member RayCo's Avatar
    Join Date
    Jul 2005
    Posts
    977
    Chester County, PA
    Kubota BX24
    Default Assorted BX questions
    Since I'm at work, I can't answer these questions for myself. And since all I can do while I'm at work is think about all the things I'm going to do on my new BX anyway, I figured I'd post some questions.
    1. Does the BX24 have any way of parking the backhoe and locking it in place? My father-in-law's Case backhoe has some sort of latching mechanism that holds the backhoe in place.
    2. The manual specifically says not to use a cigarette lighter in the 12V outlet. Anyone happen to know what amperage you can pull through that outlet safely?
    3. Is there a fuse block on the tractor, or are all the fuses inline in each independent circuit?
    4. Does anyone happen to have a BX24 owner's manual in PDF format or any other digital format?
    Thank you
    Ray
    BX24
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Join Date
    Nov 2003
    Posts
    1,251
    Tombstone Az
    BX 22
    Default Re: Assorted BX questions
    Assuming the BX24 hoe is similar to the BX22 yes it has pins to lock the boom and side to side movement. The 22 has a fuse box in the battery compartment.
  4. #3
    Join Date
    May 2006
    Posts
    359
    Spring Mount, PA
    Kubota BX24
    You have 2 pins to lock the BH in place, that normally stow by the BH controls. I always use one to keep the BH from drifting down while parked in the garage. The second pin prevents pivot from left to right. Not sure on the other questions.
    I have parts PDF's but not the owners manual.
    2006 Kubota BX24 owner
    TBN thread killah
  5. #4
    Join Date
    Jun 2007
    Posts
    116
    Maryland
    Kubota BX24TLB
    Quote Originally Posted by MOPAULY
    ....I have parts PDF's but not the owners manual.
    Mopauly what parts PDF's do you have?
    J
  6. #5
    Join Date
    May 2006
    Posts
    359
    Spring Mount, PA
    Kubota BX24
    I have the PDF's for the tractor, loader, and backhoe if I recall correctly. Just basically a parts list for each sub unit. Not a service manual.
    TBN thread killah
  7. #6
    Join Date
    Jun 2007
    Posts
    421
    MD and FL
    Kubota BX24
    Question 2: According to the WSM, 120 watts.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
