Page 1 of 6 1234 ... LastLast
Results 1 to 10 of 56
  1. #1
    Platinum Member SamWalton's Avatar
    Join Date
    Feb 2008
    Posts
    511
    Sallisaw Oklahoma
    Kubota B26 TBL
    Default Did I purchase the right trailer?
    I have been looking around for sometime and thought I knew what kind of trailer to buy, but after loading the B26 on the new trailer I was unsure I made the right choice. My B26 weighs a little over 4000 lbs. The trailer is rated for 7000 and weighs about 1900 it self. My problem is depending on the position I park the B26 on the trailer it appears to put a lot of stress on the supporting lumber and getting the tires to rest on the steal beams below could be a trick. Am I over reacting of should I have purchased a 7000 lbs car carrier?
    Kubota B26 w\Thumb, Quick Attach Pallet Forks, Land Pride PD15 auger, RBT1572 3-Way Position Rear Grading Blade, BB0554 Box Scraper and RCR1872 Rotary Cutter
  2. #2
    Join Date
    Sep 2003
    Posts
    1,222
    Hartselle, Alabama
    Deere 2520
    Default Re: Did I purchase the right trailer?
    I think you are all right on your trailer. You could have a few more braces added for peace of mind. Nice tractor even if it is the wrong color. JC
    Do you get many Wal-Mart jokes?
    JD 3320 LX5, KK rake and off brand box and rear blade. Millonzi grapple. Deere X495 for grass cutting.
    01 Ram 4x4 2500 CTD and 22' 12k trailer. Want a tiller and dump trailer.
  3. #3
    Elite Member
    Rest in Peace
    MrJimi's Avatar
    Join Date
    Jan 2006
    Posts
    2,504
    NorthEast, Florida
    Case 1845 C Skid steer
    What are the main side frame rails made with? It looks like angle I would suggest a minimum of 4" channel side rails and that may be on the light side.
    I hope your dealer will let you upgrade to a stronger trailer without any problems. The side rails help the main rails for better support kinda like a bridge effect
    keep us posted
    Click here for my current weather
    Case 1845C with dirt bucket, forks, 3 point quick hitch on the front, 30'. boom, 6 & 1/2 foot disc harrow, 5 foot Howse RC, root and tree bucket and Grouser tracks and a Ford F-550 pick up,7.3 Turbo with Auto and a Crosley 25' X 8'.6" X 14 K D/O trailer.
    PDF files don't like me !!
    Making a F-550 Pick Up thread
    My Gallery
    My other Gallery
    Revielle video here
    Dear Eliot
  4. #4
    Elite Member
    Join Date
    Jul 2006
    Posts
    3,010
    midwest
    JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
    IMHO, I think it is a little too light in construction. I would call that a landscape-type trailer. Your tractor weighs 4000 lbs, but with the backhoe on, there is a lot of weight on the front and rear tires. That weight is sitting on either wood between 2 peices of angle iron which are probably 24" or more on certer, or sitting on the 2" angle iron itself. Lot of weight for an angle iron. Those trailers can take the weight but better if spread over a wider area. I prefer 3" channel iron cross braces for equipment trailers. Preferably 16" or less on center. 24" OC would be ok for your loads.
    I have taken recently purchased trailers back and upgraded. You could also weld in more angle iron cross braces.
  5. #5
    Join Date
    Nov 2005
    Posts
    1,484
    Casey County, Kentucky
    Adding more steel to the trailer is going to add yet more weight. Will you still have peace of mind if you modify?
    I agree about going back to the dealer to see what kind of remedy you can work out. Better to get it resolved and move on.
  6. #6
    Join Date
    Feb 2008
    Posts
    511
    Sallisaw Oklahoma
    Kubota B26 TBL
    I do get the Wal-Mart jokes frequently but that is ok. I call my dealer to try to get an upgrade to a 7000 lbs car carrier with ramps I is constructed heaver. I hope to do an exchange since they wanted to use this trailer for their roofing work.
  7. #7
    Join Date
    Aug 2006
    Posts
    418
    Nottingham, N.H.
    2006 MF TLB2310
    I haul a 1533 M/F on my P/J 16 foot 7000 gvw landscape trailer, my floor won't bend or sag unless when I tighten it down with binders. I was thinking of adding a steel plate or more boards to doulble the thickness on the deck. My GC2310 wouldn't sag even when tightened down. If you loaded it backwards would that help line tires up with the steel braces below? Another thought is, if you put the backhoe down and chain it to deck that would give another place to disperse the weight of tractor. plowking
  8. #8
    Join Date
    Aug 2006
    Posts
    418
    Nottingham, N.H.
    2006 MF TLB2310
    I looked at your pictures again. Do you have brakes on one axle? Sometimes better to have brakes on both axles depending on gvw of trailer. plowking
  9. #9
    Elite Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    2,758
    Central Square, NY
    2615 HST FEL
    The trailer you have looks to be a landscape or light construction type trailer (usually about 76" between fenders, car haulers are about 82" between). The trailer you have will do the job but not leave much room for hauling any additional attachments. According to your previous post it looks like you may be able to trade up. If not then you can beef up your boards by bolting on steel or aluminum plate. The plate should at least cover the span between crossbraces. Additional crossbraces could also be added. I also saw your pics and hope you're able to trade up to a higher capacity trailer with brakes on both axles.
  10. #10
    Join Date
    Feb 2008
    Posts
    511
    Sallisaw Oklahoma
    Kubota B26 TBL
    My trailer dealer will trade up no problem. I will bring the old one back tomorrow. The trailer I am concerned about is constructed as follows: Frame: 4x3x1/4, Top rail: 3x2x3/16, Cross members: 3x2x3/16, Tongue: 5" Channel, Uprights: 3x2x3/16, Tongue Brace: 3" Channel. This is a nice trailer but when I pull facing front, my rear tires land on the center of the only large span cross support between the two axles. Top Hat Trailers
    I think I am going to order the Deluxe Car Hauler 7000 Series found at the following link Top Hat Trailers The trailer is constructed as follows: Frame: 5" Channel, Front Bump Rail: 2" Square Tube, Cross members: 3x2x3/16, Tongue: 5" Channel Wrap, Tongue Brace: 3" Channel, Floor To Fender Height: 10" I was going to add the following options: Spare Tire & Wheel, Surge Brake 7K, Diamond Plate Tear Drop Fenders (Radius), 7000# Drop Leg Jack. For and additional $300 I could upgrade it to a 9500# GVWR. This option would add two 5200# Axles, 2 5/16" Bulldog Coupler, 225/15 Tires, 7000# Drop Leg Jack and 3" Channel Cross members.
    Do you all think this trailer will move my B26 safely? Also is the 9500# GVWR necessary? I am worried about adding to much weight for my Jeep Liberty. I have the 5K tow package and I know I will be over by 1500 lbs. I only plan on a few short trips and later I will purchase a truck. Thanks for all your advice!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
