Results 1 to 8 of 8
  1. #1
    Bronze Member shibaura_4043's Avatar
    Join Date
    Mar 2009
    Posts
    79
    Default Power Steering Fluid
    Hello, I have a Shibaura 4043 with an external PSP, I have a small leak at the steering column. I was wondering what type of fluid does it take? Thanks
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #2
    Join Date
    Mar 2009
    Posts
    79
    Default Re: Power Steering Fluid
    I guess no one knows?? Is it hydraulic fluid???
  4. #3
    Join Date
    Jun 2006
    Posts
    46
    Central Texas
    JD 5205 MFWD
    Shibaura_4043:
    The grey market forum doesn't get the traffic some of the others do, I noticed you're a new member so you may not know that. I have a grey Kubota & have waited a week or more for replies (help) but be patient, somebody will have an answer. Sorry, I have no idea on your question, couldn't you use automotive PS fluid? Good Luck.
  5. #4
    Join Date
    Jun 2006
    Posts
    46
    Central Texas
    JD 5205 MFWD
    The minute I posted that I noticed the Shibaura forum. I would jump over there and re-post your question. Lens12 is a frequent contributor to these forums, he's posted on that forum recently, you could always PM him, he would know for sure.
  6. #5
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,524
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    in almost all cases I'd use a utf fluid that met multiple specs.
    hyd fluid would likely work.. so would any 10-30w oil or atf fluid. heck.. even power steering fluid would probably be fine
    utf in doubt, is what I'd use.
  7. #6
    Join Date
    Mar 2009
    Posts
    79
    Quote Originally Posted by TXCYCLE View Post
    Shibaura_4043:
    thanks, good to know. the fluid its leaking appears to be old looking motor oil, i guess i could give that a shot
  8. #7
    Join Date
    Mar 2009
    Posts
    79
    Quote Originally Posted by Soundguy View Post
    thanks for the reply, I may flush old lubricant and fill the system utf
  9. #8
    Join Date
    Mar 2002
    Posts
    42,524
    Central florida
    can't go wrong with a flush and refill vs a top off.
Similar Threads
  1. Steering revisited Jinma 254
    By Dadsgreenpsd in forum Chinese Tractors
    Last Post: 09-16-2009, 06:30 AM
  2. Model 4530 Power Steering API GL-4 vs. Hydraulic fluid
    By indigob in forum Mahindra Owning/Operating
    Last Post: 05-13-2009, 05:13 AM
  3. brake fluid in the power steering
    By DrRick in forum Oil, Fuel & Lubricants
    Last Post: 02-10-2007, 06:26 AM
  4. BX 2200 Power Steering
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 06-15-2003, 09:47 PM
  5. Goodbye Kubota, Hello Power Trac
    By MChalkley in forum Power Trac
    Last Post: 05-20-2002, 04:52 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
