Results 1 to 3 of 3
03-29-2012, 06:58 PM #1New Member
- Join Date
- Mar 2010
- Posts
- 8
3510i Will not move
Hey Guys,
I loaned my tractor to a friend this past weekend and when I received it back I noticed that the clutch was slipping when I was moving some dirt around. Today I tried to adjust the clutch sleeve and can't get the tractor to move front or backwards. Does this sound as the clutch is completely out? Thanks in advance for any help.
04-13-2012, 01:28 AM #2Elite Member
- Join Date
- Sep 2002
- Posts
- 2,653
- Location
- Red Bluff, CA
- Tractor
- Changes often!
Re: 3510i Will not move
Start by seeing if you can adjust the clutch rod until you have about 3/4" to 1" of freeplay in the pedal. I say this just in case your friend messed with it and you are all out of whack on adjustment.
But if you can't get the clutch to work by adjusting the clutch rod linkage, it sounds like your clutch might be shot. Not an simple chore on a Branson, and not cheap either. Hope it is something easier.Dave
Red Bluff, California
04-13-2012, 01:57 AM #3Bronze Member
- Join Date
- Feb 2012
- Posts
- 79
- Location
- Erin, TN
- Tractor
- LS U5030C
sounds like you might have adjusted the clutch the wrong way
Similar Threads
Tiller Dolly to move a tiller
By downtoearth in forum AttachmentsReplies: 15Last Post: 05-12-2012, 11:30 AM -
Move barn or tear it down?
By Lomillialor in forum Rural LivingReplies: 25Last Post: 03-04-2011, 11:53 AM -
YM276 won't move from time to time
By benkohn in forum YanmarReplies: 7Last Post: 07-22-2008, 10:19 PM -
3-Point Hitch 3pt-time from lever move to 3pt move
By Ken Cunningham in forum John Deere Owning/OperatingReplies: 10Last Post: 05-25-2008, 08:44 PM -
Yanmar FX265D won't move
By Same in forum Parts/RepairsReplies: 0Last Post: 06-26-2005, 01:52 PM
