Results 1 to 7 of 7
03-30-2012, 08:46 PM #1Veteran Member
- Join Date
- Nov 2005
- Posts
- 1,487
- Location
- Casey County, Kentucky
Loaded my back tires today.
Warning, some of this might upset some. I had to bury a horse last week (she was coming up on 32, it was time) and had some weight issues.
I had placed the deceased horse on a sheet of plywood and picked it up with my forks with no issues. However, when I went to lower the animal into the grave, I had the chains hanging from the tips of my forks which put the weight to far foraward and took to much weight off the rear end. Got as little hairy but I managed to get the horse in and keep myself and the T9 out of the hole.
My tires are original circa 2001 and have had some slow leaks. I had tubes put in and calcium on the rears. The fronts were so bad, we put "boots" and tubes in them. When I got everything back together tonight, one of the fronts was leaking so I did not get to move the unit around. Guess the tube got pinched.
I am anxious now to see how much difference the weight makes.
While I had the rear wheels off, I pulled the rear drums off to inspect the brakes. Lo and behold, standard rear axle drum brakes that the emergency uses. So, I cleaned them up, put the drums on and adjusted them. They ought to hold better now.
04-01-2012, 11:22 AM #2Elite Member
- Join Date
- Oct 2003
- Posts
- 2,765
- Location
- the Steernbos (Holland)
- Tractor
- Zetor 3011, Zetor 5718
Re: Loaded my back tires today.
So if i read literally, you loaded the back tires to be able to control dead horses... Do you have that many dead horses to worry about ???
Free scrap is a good investment !!!
“The worst enemy of life, freedom and the common decencies is total anarchy; their second worst enemy is total efficiency” · Aldous Huxley
__________________
1967 Zetor 3011, restoration in progress: Technically new, just needs the cosmetics..
1973 Zetor 5718, home made loader
1998 Volvo S70 TDI
2007 Volvo 440 1.9 TD based dirt buggy, needs time !
04-01-2012, 08:45 PM #3Veteran Member
- Join Date
- Nov 2005
- Posts
- 1,487
- Location
I have a 27 year old Quarterhorse stud, a 27 year old Arabian and a 26 year old Arabian. The stud is pretty arthritic though still eating. The 27 yr old Arab is a grey loaded with melanoma's and the 26 yr old Arab has COPD and other issues. Just might be a busy year.
I loaded the back tires to enhance being able to back up a grade a little better and to be able to lift pallets with material on them in addition to being able to handle a 1000lb horse.
04-06-2012, 09:57 PM #4Veteran Member
- Join Date
- Nov 2005
- Posts
- 1,487
- Location
Well, I got to test out my weighted tires today. We had to put the quarter horse down. (I knew it was coming but I did not think this soon)
At around 900-1000 lbs, he gave me and the machine a workout. I don't think I could have handled him without the added weight plus three 40 lb bags of lime on both fenders.
No problem picking up the weight per sey until I had to hang it off the tips of my forks with the loader frame raised all the way up. I had to take my time and try to keep the machine level as I could.
Anyway, I got that task finished then went on to do several other chores with the machine. For the normal kind of work, the weighted tires really made a big improvement.
04-09-2012, 09:39 PM #5Veteran Member
- Join Date
- Nov 2005
- Posts
- 1,487
- Location
04-10-2012, 08:57 PM #6Veteran Member
- Join Date
- Nov 2005
- Posts
- 1,487
- Location
Thanks, while changing out the hydraulic filter and fluid recently, I did find some loose bolts here and there. Question for you on backhoe bushings. I have quite a bit of play in the verticle pin area that allows the side to side swing. Are those nylon or bronze bushings? The machine is a circa 2001.
04-12-2012, 10:18 PM #7Veteran Member
- Join Date
- Nov 2005
- Posts
- 1,487
- Location
Similar Threads
loaded tires - worth keeping loaded?
By RobertN in forum Owning/OperatingReplies: 18Last Post: 04-27-2010, 09:21 PM -
Tires New-Used tractor tires and problems
By Hookblock in forum Owning/OperatingReplies: 7Last Post: 03-17-2008, 10:33 PM -
JD 4000 series wheel bolts
By Anonymous Poster in forum John Deere Owning/OperatingReplies: 5Last Post: 04-13-2002, 10:56 AM -
Chain of command
By Anonymous Poster in forum John Deere Owning/OperatingReplies: 9Last Post: 04-13-2002, 06:17 AM -
Tires Air pressure in loaded tires?
By Von in forum Kubota Owning/OperatingReplies: 2Last Post: 04-27-2001, 09:04 PM
