Results 51 to 60 of 60
10-08-2012, 08:49 AM #51Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,483
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Re: 1952 Ford 8N won't start
that's the kind of post that is less than helpfull on the surface..
the op stated in post 1 that his machine was negative ground.
makes -0- difference what it left the factory as 64 ys ago.. matters what it is now.
aside from that i'm staying out of the pi$$ing contest.
i'm here to fix old tractors.. that's it.
soundguy
10-08-2012 08:49 AM # ADS
10-08-2012, 08:51 AM #52
10-08-2012, 09:39 AM #53New Member
- Join Date
- Sep 2012
- Posts
- 9
- Location
- york, pa
- Tractor
- 1947 Ford 8N 6v positive ground system front mount distributor sn 10101 all OEM
OK, will check on that. Here is another question:
Should the distributor (front mount) turn free and easy when removed from the tractor, i.e. held in hand?
I ask because after having replaced points and condenser I noticed the spring clip inside was slightly displaced/not seated all the way around the groove. When I push the clip into place forcing the plate down (which I would imagine is the correct arrangement), the distributor becomes very hard to turn by hand. When the clip is slightly dislodged and the plate rises (about 1/16) then it spins more freely. Could this be an indication of some internal distributor problem?
10-08-2012, 09:43 AM #54Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,483
- Location
- Central florida
- Tractor
yes, it should turn freely and not bind.
check her out. check out bushings and breaker plate.
10-08-2012, 10:21 AM #55Elite Member
- Join Date
- Feb 2011
- Posts
- 4,156
- Location
- Frederick County, VA
- Tractor
- Kubota BX2360 & L4240 HSTC
The reason I orignally said that was because the OP had his battery hooked up backwards. Then Don was accussing me of not knowing what I am tallking about. I guess I'm the bad guy for that.
Originally Posted by Soundguy
Roger
My Threads
10-08-2012, 10:33 AM #56Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,483
- Location
- Central florida
- Tractor
backwards is a point of view from a realative position.
in reality, the generator can be polarized to run positive or negative ground.
the coil leads can be swapped.
at that point.. ground polarity is just what post is tied to the chassis.
there is a small issue of thermionic emission or edison effect with that polarity.. but not enough to make any tangible big deal about.
the main issue is once it is stated what the current ground polarity is.. you then give troubleshooting details based upon the current setup, that way the OP can follow them more easilly. or.. at least that's what i like to do.. otherwise you risk confiusing the issue telling them how to trouble shoot something that's hooked up differently. which, can cause confusion in observed vs expected measurements.
soundguy
10-08-2012, 10:47 AM #57Elite Member
- Join Date
- Feb 2011
- Posts
- 4,156
- Location
- Tractor
In reality his battery was hooked up backwards but lets get this thread back on topic and get this guys tractor running.
Roger
My Threads
10-08-2012, 11:00 AM #58Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,483
- Location
- Central florida
- Tractor
in reality, his battery was hooked up.
it was hooked up differently than it left the factory... but yeah.. I agree.. jumping up and down saying i'm right, i'm right about battery polarity ain't helping him any.
I've been 'moved on ready' since the first few posts.. your turn now..
10-08-2012, 11:01 AM #59Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,483
- Location
- Central florida
- Tractor
10-09-2012, 09:14 PM #60Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,483
- Location
- Central florida
- Tractor
i wouldn't even call myself a mechainc.. but i do like beating on old iron...
Similar Threads
1952 Ford 8n...worth buying?
By bige1973 in forum Owning/OperatingReplies: 31Last Post: 06-09-2013, 12:30 PM -
1952 8N Ford
By Laurieshood in forum Ford Vintage TractorsReplies: 7Last Post: 06-05-2012, 04:18 PM -
1952 ford 8n
By smitty1127 in forum Private Party AdsReplies: 11Last Post: 02-18-2011, 10:55 PM -
Oil & Fuel 1952 Ford 8N fuel problem?
By denden1960 in forum New Holland Owning/OperatingReplies: 5Last Post: 05-04-2010, 01:25 PM -
1952 ford 8N restoration
By Soundguy in forum Ford Vintage TractorsReplies: 12Last Post: 08-23-2002, 05:08 PM
