Linear actuator for power SSQA?
   / Linear actuator for power SSQA? #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
I've been getting kind of lazy swapping between pallet forks & my bucket. This has resulted in me dropping the forks once or twice because I forgot to latch down the SSQA levers.
Doing a setup like Power Bob-Tach Bob-Tach Attachment Mounting System - Bobcat Company would be pretty cool. I believe they usually only use one cylinder for tractor or skid steer type arms though.
I figure installing that hydraulically will be around $100 for the cylinder, $100 for the hose & a couple hundred for a diverter or valving. Hydraulics are going to be stronger than a linear actuator, but for this use case strength & shock loading really won't be an issue. If I can do it by hand, it's well under 200lbs of force & not going to be taking any impacts from a load like loader cylinders would or what not. Really it won't even need any holding force, as the levers hold themselves open or closed once thrown.
I've done a bit of searching & seen stuff for under $150, even when you figure in switches & wiring. which looks a fair bit cheaper than hydraulic options.
https://www.servocity.com/html/180_lbs__thrust_linear_actuato.html#.VBMqjPldU-A
12 Volt Linear Actuators, DC Linear Actuators and Waterproof Linear Actuators
Is a linear actuator going to work in this application, or am I missing something?
   / Linear actuator for power SSQA? #2
   / Linear actuator for power SSQA? #3
This looks like a cool idea for a cheap price. I mean the QA is awesome, not getting off the machine to hook up the implement is just a bonus. Looks like they just hooked the actuator onto the existing pivot pins for the main pin on the SSQA, Im assuming the actuators have enough power to pull and push that handle over center?
The guy that made this recommended not less that a 250lb actuator.
I finally got around to doing some research on a linear actuator for power/remote activation of your SSQA pins...
$60 China Ebay special
  • Some of them have IP 54 or IP 65 rating which means they should be weatherproof (higher number is better, first digit is dust/dirt, 2nd is water)
  • Some of them have adjustable limit switches so you should be able to set it to only do the 3.25" stroke needed as I measured on my Kubota
  • None of these had a weatherproof rating though
  • Generally topped out at around 300lbs of force, although many that advertised that later clarified they would withstand 300ish lbs of force, but would only apply 100lbs or so
  • Most seemed to actuate at around 1cm per second, kind of slow
  • 10 seconds or so to actuate the full 4" stroke
  • Top out about 5@ of power usage
  • Some note having an overload clutch, some don't
$300 option from lots of reasonably reputable places
  • Rated 500-700lbs of force
  • Usually IP 54 or 65 rated
  • Usually has adjustable limit switches
  • Seems to be in the ballpark of 1/2 to 1 inch per second
  • Top out at 15-20@ of power usage
  • Most seem to have thermal overload protection & an overload clutch
I just picked up a 4" Heavy duty 330lbs Linear Actuator multi-function for electric ,medical,auto Use for $54 with free shipping from China. It should be here whenever it makes it across the pond. I should be looking at few bucks worth of wire & switch. Probably an hour or 2 of fabbing up some brackets and a couple bucks worth of scrap or spare steel I have laying around.
I'm thinking I might be creating some artificial slop with an oval hole so I can get the 3.25" of travel out of a 4" actuator without bottoming out the actuator. Or I might see if I break things just bottoming out the actuator with 3.25" max of travel on at 4" actuator (I don't see a clutch noted on the one I bought).
I was planning on using momentary switch, but just realized if I used a toggle switch the non-adjustable limit switches should stop things before it breaks if I use the slop in the linkage to take up the extra 3/4". It might be nicer to flip the switch & wait for it to auto-stop after the 10ish seconds rather than holding the switch for 10 seconds.
It should be an interesting project to see if this works reasonably well. Depending I may look at the better actuator if this works well other than the actuator being of expected cheap Chinese quality.
   / Linear actuator for power SSQA? #5
Thanks for ;posting. Im following closely. Pics would be cool also if possible..
Will do, did some decent write ups for some other mods & projects I've done. The actuator is on the slow boat from China, so no progress on building anything until it arrives.
   / Linear actuator for power SSQA? #7
Also interested to see how this turns out!
   / Linear actuator for power SSQA? #8
Fallon- I like this. I hope the power is enough for pulling and pushing the pins without the lever advantage. I like hydraulics for this, but might be too complicated and costly for the casual user. I did find a couple of small cylinders, but there are better choices out there, I trust.
PhD Hydraulic Cylinder 09628056 04 1206 AVP 1x1 2 B M | eBay
Opps- although they claim they are hydraulic, they are for pneumatics. But the idea might work... not with these, of course.
I know linear actuators will work. Several skid steer OEMs actually use them (higher quality ones I'm sure). The big question is if my $54 one will. I know a 500lbs rated unit would & I heard somebody else say 250lbs should work. I haven't bothered doing the math on the mechanical advantage of the lever arm, or even measuring the force it takes to operate the levers for that matter. If it doesn't work I can reuse the actuator for other stuff, not sure if I'll bother shelling out for a better one if the cheap one doesn't work. I hear most of the times they use hydraulics they have to put in a pretty low relief valve so the hydraulics don't tear things up.
As far as cost I'm looking at $10 in wiring, maybe $10 of steel that I'd otherwise have lying around & the actuator. To do it with hydraulics I'm looking at at least $50 for a cylinder, probably another $50-100 in hoses & fittings as well as at least $100-150 for a valve or diverter. If I was going that route I'd probably plumb in a spare 3rd function as well as my SSQA circuit, which would probably mean a $250ish diverter.
   / Linear actuator for power SSQA? #10
Varmint - this isn't directed specifically at you...
Our DIY projects always have to balance cost/time/effectiveness. My snowblower project took way to long to complete, but it really works well. It would have been another $1000 to add hydraulics to the system. I'm sure there'd be some gain but I'm not sure it'd be worth the extra expense.
These actuators are the same scenario. I'm sure hydraulics would work better per-say, but the cost factor can't be overlooked. That being said - I've also been guilty of trying to get by on the most inexpensive thing possible and have it bite me later. Again - balance.
   / Linear actuator for power SSQA? #11
Here is a picture of a linear actuator on something.
   / Linear actuator for power SSQA? #12
I agree that hydraulics would be costly and much more complicated. If you can find a linear actuator that is truly waterproof, and has enough grunt, then even if it costs $100 it makes perfect sense. J J's photo shows a simple installation, if the leverage works. Pivoting higher up on the lever arms would certainly do it, but then you'd have stuff in the air. Maybe a second set of levers is needed. Interesting.
I was looking at that, but the angles are wrong. If you mount the actuator to the ends of the handles you wouldn't get a full movement. As the levers go over center they are closer to each other in the middle of the throw than at the ends. We have the same issue a hair mounting to the small end of the lever, but not nearly as much. Mounting the actuator vertically attached to a cross-member between the long lever ends might work. But rather than go that route I'd get a better actuator for the lower horizontal option, which seems to be the industry standard.
As far as your "truly waterproof" the one I ordered is rated at IP 65
IP Code
6 Dust tight No ingress of dust; complete protection against contact (dust tight)
5 Water jets Water projected by a nozzle (6.3 mm) against enclosure from any direction shall have no harmful effects. Test duration: at least 3 minutes Water volume: 12.5 litres per minute Pressure: 30 kPa at distance of 3 m
Weather nor not my $54 China Ebay special lives up to the rating is another story... Something IP54 rated might be enough & I saw several cheap ones with that rating, but probably isn't the best idea & I didn't want to try risking one.
   / Linear actuator for power SSQA? #14
Just an FYI ,anyone looking for a linear actuator, I found Auto Express on eBay and called them for one. Great service and very helpful. Very reasonable price too. Put one on the 3 pt snowblower and use the remote to adjust it up and down. In case anyone's looking for one quick and reasonable....
   / Linear actuator for power SSQA? #15
I have also thought about using linear actuators on the SSQA. It will be interesting to see how it works out.
   / Linear actuator for power SSQA? #16
A self contained electric over hydraulic actuator would work too, if you could find one. Power of hydraulic with convenience of electric. Probably more expensive though.
A $300 linear actuator is rated 600-100lbs, so the power isn't an issue with a linear actuator. My build is suspect because I'm using a cheap Ebay $50 actuator rated to 330lbs tops (If I'm lucky, it may even do what it's rated to). I'd much rather go with a native hydraulic solution than electric over hydraulic. Electric over hydraulic is the worst of both worlds, 2 different component adding complexity, expense & weight out there on the boom.
   / Linear actuator for power SSQA? #18
Air would be cheaper and very easy. A little 12v tire pump would handle it in stride.
Got the actuator & it's more or less what I was expecting. A bit slower to cycle than I was hoping for at 15 seconds or so. Unsurprisingly I'm unable to stop it or slow it down much with my arm strength. I know I don't have 100lbs of strength to try to freehand squeze it together, much less the 300ish it's suppose to be rated for.
As the weather has briefly cleared up to look like this, it might be a while before I make any progress. Any trips out to my unheated shop are going to involve plowing & that's it.
   / Linear actuator for power SSQA? #20
Good luck, but for me, it would be too slow. On the other hand, pulling and pushing my lever arms doesn't seem to take an extraordinary amount of grunt, so if you can take advantage of lever motion, maybe you can make it work. I will be interested to see how it plays out!
2018 Ford F-350 (A55973)
2018 Ford F-350...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
2011 CATERPILLAR 279C SKID STEER (A60429)
2011 CATERPILLAR...
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
