DIRTCUTTER
CK30 bh/fel/sb 97 hrs. I changed the engine oil and filter, the only problem is I added to much oil, 3 and half gallons worth. I was thinking 2 quarts to a gallon. After I completed the oil change about an hour later while using the tractor I got a huge puff of white smoke coming from the exhaust pipe. I turned off the motor waited a few minutes thinking the motor overheated. Started the motor again, same thing white smoke and a sound like a rod knock. I when over everything I did that day to the tractor, and after counting the empty bottles of oil and checking my service book I realized what I did. I then drained out the oil, added new oil to the proper amount. I used the tractor for about 5 minutes this morning I didnt want to push it until I find out more about what damage I might have caused and it seems to be operating ok. My question is what damage if any did I do to the motor.
