Results 1 to 6 of 6
  1. #1
    Member
    Join Date
    Oct 2006
    Posts
    37
    Default Alternative snow plows for JD 2320?
    Hi all-looking at purchasing a JD 2320 with FEL and 62"mmm. The snow plow available from JD is a 54" front-mounted bade that many TBN'er's say is not wide enough when the blade is angled-the blade doesn't cover the back tire
    which then makes the job more difficult by compacting the un-plowed snow. Some guys bolt extensions to the blade to add the necessary width but I'm curious if there are other solutions? Thanks-Phil D
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,913
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: Alternative snow plows for JD 2320?
    There are not really other options unless you cab weld/fabricate. I made an older JD #380 blade fit my machine (pictures in the link in my sig). The extensions are the easiest way.
    I wish JD would get on the ball with this!
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Veteran Member CinderSchnauzer's Avatar
    Join Date
    Apr 2006
    Posts
    1,407
    In terms of new and or used blades check with the kubota or MF dealers. The 60" power angle blade on my Honda looks identical to the 60" blade used on the MF GC23xx series. The QA bracket mounts on the front weight bracket by means of a screw clamp. At one point I was seriously considering mounting the Honda blade on my 3320, but just kept the Honda tractor / blade instead. Here is a pic of the MF version - 60" power angle blade.
    The JD weight bracket may be a bit small, but if you need the exact dimensions for the MF QA I could send them to you later. From memory about 13" x 5" x 3/8" is fairly close. It would be easy to get a correct size made that could just bolt on the existing JD bracket.
    Attached Images Attached Images
    2007 JD CAB 3320 eHydro, 300CX FEL, GX720 Back Hoe, 72" 7-Iron MMM, 48" Horst Pallet Forks
    Lucknow 60" Rear Snow Blower, JD Box Blade 2065
    2013 JD X739 - 60" HC Deck with Auto Connect
  4. #4
    Join Date
    Jul 2006
    Posts
    70
    Ohio
    John Deere 790,John Deere 2025R & Steiner 440
    You might want to contact Arthur Randall Corporation to see if they have one for the 2320 or not. I have a 2305 myself with the JD 54" blade and I would prefer it to be 60" also. They have some videos on their web site of the plows they are making right now. I will try to post the link for you to the page but I am new at this just in case it does not work please forgive me.Arthur Randall Corporation
  5. #5
    Veteran Member Gizmo2's Avatar
    Join Date
    Jul 2006
    Posts
    1,918
    New York
    JD 2320
    Phil D,
    I will add my two cents in about plow width for the JD2320. A 54" plow width is without question too small for the 2320. A 54" inch plow blade angled to a full 30 deg. will leave a path approximately 47 inches wide (maybe), my 2320 measures approximately 50 inches across the rear tires. I have been running a homemade 66" for about 23 years, 21 years was with the plow attached to a JD650 which is smaller than the 2320. I am seriously thinking about a new blade of 72 inches. I may sell my old blade, maybe!
    Alternative snow plows for JD 2320?-dsc_0042_1-jpg Alternative snow plows for JD 2320?-0004aml_1-jpg
    JD 2320, 200CX FEL/61" bucket , 46 BH/16" bucket, FEL Forks, 72" Snow Blade, Landscape Rake, Ballast Box, PHD, The Wife
  6. #6
    Member
    Join Date
    Oct 2006
    Posts
    37
    Do you think I should forge ahead with the 54" plow and weld on extensions or abandon the JD plow and go a different route altogether? Many users advocate the 54" plow and the retrofit afterwards.
Similar Threads
  1. Rear snow blower or front mounted snow blower
    By Doc_Bob in forum New Holland Buying/Pricing
    Last Post: 10-29-2012, 01:04 PM
  2. Snow Kubota B21 & Snow Plows
    By Whitey in forum Kubota Owning/Operating
    Last Post: 02-11-2010, 05:57 PM
  3. Snow, Snow, & more Snow!!!
    By bpence in forum Rural Living
    Last Post: 12-20-2000, 11:52 AM
  4. Snow Fun in the Snow
    By RobS in forum John Deere Owning/Operating
    Last Post: 12-15-2000, 10:41 PM
  5. Snow Attachments Snow Plows
    By Corm in forum Snow Removal
    Last Post: 10-15-2000, 08:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
