Page 30 of 431 FirstFirst ... 20272829303132334080130 ... LastLast
Results 291 to 300 of 4304
  1. #291
    Elite Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    3,501
    NorthEastern, VT
    Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
    Default Re: Pictures of your snow weapons
    Quote Originally Posted by nybirdman View Post
    Gordon Gould,
    Nice collection....what would your wife say if you didn't have all that equiptment and she couldn't get out to go shopping!
    We have friends in Morris,VT.You need it all my friend.
    Thanks. If you mean Morrisville thats not to far from here. I do use all that stuff to keep things open.
    It's the picture taking and showing them to you guys that puts me in the wacko catagory. But I think it is fun.
    gg
    "If you're not making any mistakes then you're not doing anything"
    M5640SUD, L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' & 7' Rear Blades, 7' Box Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  2. #292
    New Member
    Join Date
    Dec 2004
    Posts
    2
    Quote Originally Posted by beenthere View Post
    You asked for pics of our machines, and not the neighbors.
    This is mine, and the blade sits in the shed until the snow comes. About a 5 min. job to drop the FEL, roll out the blade and about another 5 to tilt it up and secure with two bolts. Plug in three QC's and off we go. If deep and wet, then add the ladder chains.
    If deep, then add the wing plow which is at most 5 minutes to attach.
    SO is the wing a home made item?? could you post a few more pics of the front mount
    Thanks
  3. #293
    Super Member CompactTractorFan's Avatar
    Join Date
    Jul 2010
    Posts
    7,963
    Pennsylvania
    Kubota BX25
    Quote Originally Posted by Gordon Gould View Post
    Finally pulled my plow out of the woods and got my weapons to stand for a photo. Wife thinks I'm wacko.
    We certainly have a large assortment of snow fighting equipment here !
    Here is mine.
    You look well prepared!!!
    Kyle - CompactTractorFan
    Kubota BX25 w/R4's (23 hp, 17.7 PTO hp), Loader, Backhoe, 60" Mid Mount Mower, Cyclone Rake Z-10 Lawn Vacuum, CountyLine Carryall, Ferris 48" Walk-Behind Mower, Honda 21" Walk-Behind Mower, Mighty Mac 4" Chipper/Shredder,
    2000 Dodge Intrepid, 2012 Ford F-150 EcoBoost
  4. #294
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    Massey Ferguson GC2400
    Here is mine.
    I gotta ask.........how many times did you re-arrange the equipment to get the right photo?
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  5. #295
    Join Date
    Apr 2007
    Posts
    3,501
    NorthEastern, VT
    Quote Originally Posted by Don87 View Post
    Two posses
    Should mention we live a the end of a mile long deadend road
  6. #296
    Super Member
    Join Date
    Feb 2006
    Posts
    6,138
    East PA or 750 mi. east of a short man named Dar___
    Kubota, AGCO, New Holland LB
    Here is mine.
    Sweet little dodge dump you got there.
  7. #297
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,776
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Quote Originally Posted by eurekadoc View Post
    Thanks
    The front mount is a bit of odds/ends but consists of a square tube that slides over the 3" square FEL stub. A steel bar drops down from that tube (box) with a trailer ball welded on the end, that connects to an old cast trailer-hitch. Drop in one bolt that slips behind the tab on the FEL stub to keep the front mount from sliding off. Just slip the front mount on and drop in the pin/bolt.
    It is designed to possibly raise and lower if a different front height might be better. Tack welded the drop bar now, but thought of an advanced design to raise and lower it.
    Also designed to fit on the right or left side FEL stub for a right wing or a left wing. I'm right winger will leave it there
    I see no immediate reasons to want to change it, as it works exceptionally well.
    Shown here before paint.
    Attached Thumbnails Attached Thumbnails Pictures of your snow weapons-100_1574-medium-jpg
  8. #298
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,929
    Northern Vermont
    Kubota, Case, Deere
    Here is mine.
    Kind of pushed your luck a little. I've had the plow and chains on the International now for almost month. I don't mind putting the plow on in the cold weather but tire chains on tandems just sucks unless it's above 50 out.
    I happened across one of your old posts on tire chains for your tractor. I called Desmarais and ordered a set. They were cheaper than what I could find on the internet. I even think I got the same type as you.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  9. #299
    Silver Member nwltruck's Avatar
    Join Date
    Nov 2010
    Posts
    158
    north west Iowa
    '07 John Deere 3320
    just got this new toy. 7' ber-vac snowblower found on ebay $600. was a front mount but the previous owner hit a curb and bent the rear power unit so I removed that and added the 3pnt mounts.
    Attached Thumbnails Attached Thumbnails Pictures of your snow weapons-phone-pictures-016-jpg
  10. #300
    Elite Member Rob-D's Avatar
    Join Date
    Oct 2006
    Posts
    3,078
    Catskills
    John Deere 3320
    That's a tricky attachment to build, nice job on that Beenthere!
    Rob
Similar Threads
  1. Snow Equipment Owning/Operating Another winter storm = snow clean-up pictures
    By Northland in forum Snow Removal
    Last Post: 12-01-2013, 02:39 PM
  2. Snow Tractor Questions
    By mmranch in forum Customization
    Last Post: 10-07-2010, 08:33 AM
  3. Snow Equipment Owning/Operating SNOW REMOVAL PICTURES
    By macmax55 in forum Snow Removal
    Last Post: 02-24-2010, 02:04 PM
  4. Snow Equipment Owning/Operating plowing, Loading and throwing deep snow pictures
    By Raddad in forum Snow Removal
    Last Post: 01-07-2007, 09:23 AM
  5. Snow Attachments Survey - plowing snow with a rear blade
    By Wheeldog in forum Snow Removal
    Last Post: 12-03-2001, 02:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
