Results 1 to 10 of 13
10-22-2010, 04:50 PM #1Bronze Member
- Join Date
- Sep 2009
- Posts
- 82
- Location
- Green bay, Wi
- Tractor
- 09 farmall 45w/ 350 loader 08 cat 420e w/cab john deere 110 Inter dump truck w/plows 06 Arctic cat Prowler
3320 john deere snow plow help
I have a 3320 and i just pick up a snow plow. I don't want to hook it up to the fel because of the problems it can cause. I saw a couple of guy mount it the front and used the loader outputs to control it. My questions are what size cylinders do i need, and what is the psi. Where do i get the quick couplers to hook up to the fel couplers. Also, were is a good place to get my part at a good price
10-22-2010, 05:03 PM #2Platinum Member
- Join Date
- Nov 2008
- Posts
- 546
- Location
- Central Illinois
- Tractor
- Many JD
Re: 3320 john deere snow plow help
I put a 7' myers plow on my 3320 loader and it has worked fine but you guys have real snows up there. I mounted mine to my fork lift frame and used the hydraulics for my 4 in 1 to angle the plow.
Dan
10-22-2010, 06:19 PM #3
John Deere 4110HST
FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Simple JDParts Tutorial HERE
10-24-2010, 08:45 AM #4Bronze Member
- Join Date
- Sep 2009
- Posts
- 82
- Location
- Green bay, Wi
- Tractor
i will get some pictures soon, it is a 8ft western plow blade with single acting cylinders. It came off a truck I it just the blade and a frame. I will fab my own bracket to fit the tractor. Also i am trying to decide to use a chain or use the float control.
10-24-2010, 09:18 AM #5
John Deere 4110HST
10-27-2010, 08:37 PM #6Bronze Member
- Join Date
- Sep 2009
- Posts
- 82
- Location
- Green bay, Wi
- Tractor
do i have to use a SA cylinders or can i use just regular hydraulic cylinder instead. the reason i am asking is because a SA cylinder is $80 and would have to have two. Where i could get on regular cylinder for the same price. Would there be any problems with this.
10-27-2010, 09:20 PM #7
10-27-2010, 09:22 PM #8Bronze Member
- Join Date
- Sep 2009
- Posts
- 82
- Location
- Green bay, Wi
- Tractor
I am using a regular for the lift. I was talking about the angle on a western blade
10-27-2010, 09:29 PM #9
10-27-2010, 09:46 PM #10Bronze Member
- Join Date
- Sep 2009
- Posts
- 82
- Location
- Green bay, Wi
- Tractor
what kind of modifications couldn't i use the same location of the one of the SA cylinders.
Similar Threads
John Deere 2305 Compact Tractor Transmission and rear PTO failure
By JBarnes6767 in forum John Deere Owning/OperatingReplies: 60Last Post: 04-28-2013, 10:48 PM -
john deere L plow
By tglass in forum John Deere Vintage TractorsReplies: 5Last Post: 04-07-2010, 11:48 AM -
Dealer Another Deere dealership pulled
By dgl24087 in forum John Deere Buying/PricingReplies: 36Last Post: 01-29-2010, 07:36 AM -
Rear chains
By andrewimbrogno in forum AttachmentsReplies: 32Last Post: 12-30-2009, 11:40 AM -
Nice lunch with John Deere reps.
By cowboydoc in forum John Deere Buying/PricingReplies: 27Last Post: 09-02-2003, 09:48 PM
