Page 1 of 23 123411 ... LastLast
Results 1 to 10 of 227
  1. #1
    Silver Member gladehound's Avatar
    Join Date
    Mar 2007
    Posts
    244
    PA
    Kioti LB1914
    Default Cutting / Groving / Siping R-4 for snow
    I know R-4's in snow has been discussed to death but after a quick search I couldn't find anything about cutting them for better performance. I recently picked up an Ideal Heated Knife, also known as a tire groover. With a little help from a forced air heater to really get the tires warm, it worked like a charm. (I tried to go to work on 10 degree F tires at first and it was slow going)
    My plan is to both groove and sipe my R-4's for better traction. This evening, I did the grooving part. 20 minutes for the first rear tire, 15 minutes for the second (since I had some practice on the first). Here are some pictures of what I did. I'm hoping this improves snow traction some.
    When I get a chance I will sipe them on either side of the grooves for even better traction in hard packed snow/ice. The theory is, the more biting edges the better the snow/ice traction.
    It's snowing now, I'll see how they go in the morning!
    Attached Thumbnails Attached Thumbnails Cutting / Groving / Siping R-4 for snow-groved-tire1-medium-.jpg   Cutting / Groving / Siping R-4 for snow-groved-tire2-medium-.jpg
    Ron
    2004 Kioti LB1914 w/ FEL
  2. #2
    Veteran Member jake98's Avatar
    Join Date
    Nov 2007
    Posts
    1,905
    Quarryville, NJ
    53 Cub, 70's JD 410, Kioti 25hst
    Default Re: Cutting / Groving / Siping R-4 for snow
    Nice job! Did you have to do some soul shearching before starting that?
    Kioti CK 25 Hydro: box blade, brush hog, rake, roto-till, grapple, bucket forks, de-stump cyl, Wallenstein Chipper
    John Deere 410 Backhoe Loader: 25 hoses ready to blow
    Thus by the beneficence of Providence, we shall behold our empire arising, founded on justice and the voluntary consent of the people, and giving full scope to the exercise of those faculties and rights which most ennoble our species.
    Samuel Adams
  3. #3
    Join Date
    Apr 2010
    Posts
    975
    DO you ever load heavy with the FEL? If you do, and spin the tires slightly, siping will all the force to tear them up quick. Just a word to the wise.
  4. #4
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,113
    Front Range of Colorado
    JD 4200 C.U.T. & JD 130L Lawn tractor
    Please let us know how well that works out for you.
    Моє щоденне меню для терористів: бекон на сніданок, бутерброди з шинкою на обід, і вечерю свинячої відбивної
    Stuff I've made for the JD4200 or done with it are at this link.
    http://picasaweb.google.com/mjncad
  5. #5
    Gold Member kday64's Avatar
    Join Date
    Nov 2010
    Posts
    350
    South Eastern Connecticut
    Kubota BX2360
    Default
    Did you make a template first or did you go freehand?
    Looks good. Keep us posted.
    ~Kevin
    Kubota BX2360, 54" Fine Cut MMM, LA243 FEL, BX2789 Rear Snow Thrower
  6. #6
    Join Date
    Mar 2007
    Posts
    244
    PA
    Kioti LB1914
    "Nice job! Did you have to do some soul shearching before starting that?"
    Thanks! Not too much, I like to mess with stuff.
    "DO you ever load heavy with the FEL? If you do, and spin the tires slightly, siping will all the force to tear them up quick."
    I hear you! I do take the tractor to it's limits. I'm going to sipe so that there is rubber connecting the lug on both sides of each sipe with just 4 sipes per lug. I think this should maintain enough strength. This is how the sipes are on my 7,000 pound truck which has much higher contact patch pressure and can spin all 4 on asphalt and has never torn a lug. So I think it will work out OK. I certainly have to be careful not to teke too much out! I've noticed that all the lugs have a 2x width to height ratio so I maintained that with the groove, only going 3/8" down with an inch remaining on each side. The groove is open ended on one side but the sipes will be close ended on both sides.
    "Did you make a template first or did you go freehand?"
    Free hand
    I'll keep TBN posted on how this turns out both in terms of traction and long term durability of the tires. Now it's time to plow some snow!
    Ron
  7. #7
    Join Date
    May 2010
    Posts
    70
    West Jefferson, NC
    Kubota B7610
    Wouldn't chains work better and not reduce the life of your tires?
  8. #8
    Elite Member RalphVa's Avatar
    Join Date
    Dec 2003
    Posts
    3,286
    Charlottesville, VA, USA
    Gravely 5665 & JD 4010
    You could also put some metal screws into the lugs.
    Ralph
    The natural gardener
    God's original intent
  9. #9
    Elite Member Duffster's Avatar
    Join Date
    Mar 2009
    Posts
    4,357
    Wisconsin
    Quote Originally Posted by NC tractor driver View Post
    Quote Originally Posted by RalphVa View Post
    Ralph
    Or studs but I am guessing he doesn't want the surface damage.
    "If everyone is thinking alike, someone isn't thinking." George Patton
  10. #10
    Join Date
    Mar 2007
    Posts
    244
    PA
    Kioti LB1914
    I used them this morning and traction in the rear was much improved. More than I thought it would be.
    We had 6" of light snow. Not much of a challenge so I took it out of 4WD and put the 6' blade strait to let the snow pile up in front and plowed the 200 foot lane from the barn to the road without slipping a tire. The groves allowed the tires to hold snow on the surface of the lugs where it would normally just fall off and this gives much better traction and one reason snow tires work as well as they do. They worked so well that I don't think I'm going to sipe them. Not unless later I think I need more traction.
    Yes, chains are fantastic for traction. But there are several reasons why avoid them.
    1. surface damage to neighbors paved driveways and to my garage floor.
    2. I don't have clearance for rear chains (design error in my opinion)
    3. I have front chains and have used them and didn't like the damage to my garage floor or neighbors driveway.
    4. I'm worried about over stressing the front axle with front chains and very heavy plow hanging off an already heavy bucket on a relatively small tractor.
    I don't believe that increased tire wear is a real concern for the rears. In theory the increased wear would be proportional to increased contact pressure. So I might get about 10% faster tire wear in the rear.
    After 420 hrs there is little wear on the rears, so I'd rather have the snow traction.
    Siping on the other hand should not increase the wear rate so long as it's done in a way that the lugs don't chunk off since contact pressure is not changed.
    The fronts are a different story and are at around 50% wear. I will not grove or sipe the fronts. There is too much contact pressure and the lugs are already only half as thick as the ones in the rear.
    Ron
Similar Threads
  1. Cutting with a gas torch
    By Ferdd in forum Welding
    Last Post: 07-10-2010, 04:03 AM
  2. Cutting angles for welding
    By Rch in forum Welding
    Last Post: 01-16-2003, 12:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
