Page 8 of 8 FirstFirst ... 5678
Results 71 to 76 of 76
  1. #71
    New Member
    Join Date
    Jan 2013
    Posts
    6
    St-Pascal, Ontario
    4320 john deere
    Default Re: Welcome to the Snow Removal Forum!
    Hi Ralph,
    So how does it go with the studs?
    thanks
  2. #72
    Member
    Join Date
    Jul 2011
    Posts
    35
    Albert County, NB Canada
    135 MF, 7010 LS, 510B John Deere Backhoe
    [QUOTE=Ralph Copp;3125872]Major storm in New Brunswick today. I am waiting for the wind to die down before taking out my LS7010 to clean up. The back tires are loaded with Agrim 50 and studs in the front. The studs help with steering on the ice. I was going to put the studs on the back tires but I thought I would try them on the front first. I don't know anyone else in my area using studs but I thought I would give them a try. The ones I purchased are Maxigrip.
    Welcome to the Snow Removal Forum!-1354390069366.jpgWelcome to the Snow Removal Forum!-1356550360798.jpg
  3. #73
    Member
    Join Date
    Jul 2011
    Posts
    35
    Studs are working good. I was worried that they might tear up the cement floor in the garage but that doesn't seem to be a problem. They don't stick out a long ways. About 3-4 mm. Next year I will probably put them in the back as well. The drive ways in my area are hilly and would help on the ice.
  4. #74
    New Member
    Join Date
    Jan 2013
    Posts
    1
    Finger Lakes region,NY
    Kubota B2620
    Meant to quote Post #69 here.
    Hello,
    I saw your message and will offer my views on upstate NY southern Finger Lakes snow removal.
    My gravel driveway is about the same length at 800 ft but uphill grade with approx. 90 degree curve at bottom with hedgerow on one side. I have the 60" front blade on my B2620 with the mid-hitch mount with power angle and lift. I can plow downhill and uphill without major issues in 4wd with R4 filled tires. With ice conditions, I need to lock rear differential and have gotten stuck once on the downgrade in a 3 or 4 foot pile of plowed snow.
    My bucket loader does not perform well on the curves and contours of the gravel and I prefer to keep snow from the culvert on one side plus avoid drifts.
    My suggestions from 14 years of plowing is to clean driveway after about 4-6" snowfall, push back edges approx 2 feet in early season and set blade height at 1" above gravel. You may be able to set lower depending on curves or banking to prevent icing. Traction is excellent with liquid filled R4 type tires but does tear the lawn when mowing. The B2620 has excellent headlights and has no problems plowing or using FEL in dark.
    Last edited by mrgp71; 01-09-2013 at 03:17 PM. Reason: forgot to quote previous quote
  5. #75
    New Member
    Join Date
    Jan 2013
    Posts
    5
    Markdale, Ontario
    JD 4200
    I have a JD4200 and currently use a rear mounted Meteor (Walco) 59" snow blower. However, back issues and surgery now limit my ability to turn around in the seat to watch the rear attachment. I am trying to find a front end snow blower or a third party adaptor kit so that I can mount a front end blower. Ideally I would like to use my existing blower with a gear reducer at the fron end. Any ideas?
  6. #76
    Super Star Member RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    15,684
    Bethel, Vermont
    John Deere 4400 MFWD
    Quote Originally Posted by woodwacker View Post
    Erskine makes a front mounted blower that's driven by the rear PTO. You could take a look at that for ideas...make even buy some of the components to rig your 3PH blower to the front.
    Ain't going to be cheap though...maybe more cost effective to contract out snow removal until you're healed.
    Roy Jackson
    A fear of weapons is a sign of retarded sexual and emotional maturity...
Similar Threads
  1. Price Check Front snow thrower for 4100 series- Price & others
    By ducati996 in forum John Deere Buying/Pricing
    Last Post: 01-16-2011, 11:07 AM
  2. Snow Equipment Owning/Operating Snow blowing rules of thumb
    By smfcpacfp in forum Snow Removal
    Last Post: 02-13-2010, 03:41 AM
  3. Buying Advice Advice on 2320 purchase for mowing and snow removal
    By JJKJ in forum John Deere Buying/Pricing
    Last Post: 12-20-2009, 08:58 PM
  4. Snow How to set up a L3130 for snow removal?
    By denver 2 in forum Kubota Owning/Operating
    Last Post: 02-21-2009, 01:12 PM
  5. Snow Snow removal with BX2200
    By Tim_in_NH in forum Kubota Owning/Operating
    Last Post: 06-05-2004, 09:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
