Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
  1. #21
    Gold Member jb62901's Avatar
    Join Date
    Apr 2009
    Posts
    273
    Cassopolis M.
    Kubota BX2360
    Default Re: Snowblower electric chute rotator motor resource.
    I to had used a car widow motor, don't know what it came out of.
    chute rotater on a B2789U - YouTube
    09 BX2360 FEL, + Tons of Attachments Many Homemade
  2. #22
    Veteran Member chopped's Avatar
    Join Date
    Dec 2008
    Posts
    1,312
    New England yankeee
    This one is not to bad a setup it sure moves fast..
    snowchute.MOV - YouTube
  3. #23
    Bronze Member TGReaper's Avatar
    Join Date
    Mar 2010
    Posts
    62
    The Keystone Prov.Canada EH.
    Kubota BX2200
    Amazing,how many ways the guys can come up with to do the same job.
    This is how I did my electric rotator. (Next come the deflector.)
    TGR
  4. #24
    Join Date
    Mar 2010
    Posts
    62
    Kubota BX2200
    This is how I did my electric rotator. (Next comes the deflector.)
    TGR
  5. #25
    Member
    Join Date
    Aug 2011
    Posts
    31
    NH
    Kubota BX23
    I am in the process of hooking up the power motor chute rotator and the power actuator for the chute deflector angle. I consider myself a pretty good back yard mechanic but I have a problem! I tried bench testing the motor and the actuator but can't get them to work. Each unit has two wire coming from them. I assumed the motor housing was the ground (-) and the the two wires from the motor were either up/down or right/left depending on which one I applied plus (+) voltage to. Maybe today I will try it right off the Kubota battery and see what happens.
  6. #26
    Gold Member mpham's Avatar
    Join Date
    Oct 2011
    Posts
    289
    Massachusetts
    Kioti ck20
    Default
    Quote Originally Posted by chopped
    That ones mine. It was easy to put together and works great. Going on second year with no problems. I already have it set to go for this year.
    Phil. from Mass.
    2008 Kioti ck20 with 380 hours
    New to me 2011 K120 loader
  7. #27
    Join Date
    Apr 2009
    Posts
    273
    Cassopolis M.
    Kubota BX2360
    Bugsrlb. Reverse the wires and see what happens, thats how it works.
  8. #28
    Join Date
    Apr 2009
    Posts
    273
    Cassopolis M.
    Kubota BX2360
    You will need a DPDT switch or the aquvelent.
  9. #29
    Member
    Join Date
    Aug 2011
    Posts
    31
    NH
    Kubota BX23
    Quote Originally Posted by jb62901 View Post
    You mean put plus (+) to the motor housing and ground (-) to the wires???
  10. #30
    Member
    Join Date
    Aug 2011
    Posts
    31
    NH
    Kubota BX23
    I did buy the DPDT switches. Thanx
Similar Threads
  1. Cub Cadet Snowblower - Converting Power Chute to Manual Chute
    By marrun37 in forum Cub Cadet Yanmar & CUTs
    Last Post: 11-28-2012, 03:03 PM
  2. DIY 59" Snowblower Manual Chute Adjuster
    By arrabil in forum John Deere Owning/Operating
    Last Post: 05-14-2010, 08:14 PM
  3. Replies: 3
    Last Post: 11-24-2008, 09:44 PM
  4. Snowblower Chute
    By Friver in forum Kubota Owning/Operating
    Last Post: 02-20-2008, 03:46 PM
  5. bl2660 rear snowblower chute rotater
    By texblonigan in forum Kubota Owning/Operating
    Last Post: 07-22-2002, 12:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
