Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Jan 2001
    Posts
    166
    I live in the state of Delaware in New Castle County ,USA
    New Holland 1030
    Default New information on Hydro vs. Manual trans for snow blower use.
    I found out today what the speed is for each gear on the Mahindra 2516 they are listed as follows.
    Low range: Gear MPH
    Reverse 1st .7
    2nd .9
    3rd 1.4
    4th 2.2
    Forward 1st .8
    2nd 1.1
    3rd 1.7
    4th 2.6
    High range:
    Reverse 1st 2.7
    2nd 3.8
    3rd 5.7
    4th 8.7
    Forward 1st 3.2
    2nd 4.5
    3rd 6.8
    4th 10.4
    The stated top speed high range Forward 11.2 MPH Reverse 9.4 MPH
    The Kubota B2320 has three range trans Hydro. Forward 0 to 11.7 MPH Reverse 0 to 9.4 MPH
    Seems to me that I should be able to use the gear without a hitch. Scaper
  2. #2
    Super Star Member RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    15,684
    Bethel, Vermont
    John Deere 4400 MFWD
    Default Re: New information on Hydro vs. Manual trans for snow blower use.
    Assuming that Mahindra has a 2-Stage clutch, even if the snow bogs you down, just depress the clutch pedal halfway to stop the tractor (blower or other PTO implement will still run) to clear itself out. This will likely be necessary if you run a rotary cutter too.
    It takes a bit of practice, but you'll pick it up quick enough.
    Roy Jackson
    A fear of weapons is a sign of retarded sexual and emotional maturity...
  3. #3
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    And you will have that extra 3-4 HP to put to use on the snow blower that wont be available on the HST so it should run a bit faster in deeper snow with the extra HP.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  4. #4
    Join Date
    Jan 2001
    Posts
    166
    New Holland 1030
    The Mahindra has a single stage clutch. I wish it were a two stage but not going to happen. I still like the low gears for tilling but then again the hydro has cruise to set even the slightest speed. I'm sure I could get used to the single stage but to change direction with the shuttle shift I still will have to depress the clutch. Scaper
  5. #5
    Join Date
    Nov 2001
    Posts
    15,684
    Bethel, Vermont
    Quote Originally Posted by Scaper View Post
    That's somewhat surprising about the single stage clutch. It will be a bit more of a hassle, but remember, folks have been running implements on old Fords, Deeres, etc for a lot of years with single stage clutches. Some of them still do...
    Roy Jackson
  6. #6
    RFB
    RFB is online now
    Join Date
    Jan 2006
    Posts
    871
    West Central Idaho
    Grand L5740HSTC, Kubota LA854 FEL with QA Bucket
    Scaper,
    HST is not "new"; its a proven technology and well established in the CUT genre despite some of the neo-Luddism that is ubiquitous within the more broad-based culture .
  7. #7
    Join Date
    Aug 2010
    Posts
    740
    Palm of the Right Hand
    John Deere 5210 + Bobcat CT335
    Quote Originally Posted by RFB View Post
    Scaper,
    ..................neo-Luddism...............
    "Wow, learned something new today" says the HST owning neo-luddist.
  8. #8
    Elite Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    4,751
    Northern Vermont
    Did anyone say you couldn't use a gear tractor with a snow blower? It's just more work. With HST you'll never be pushing a clutch.
    Just yesterday we got about 4" of snow and I was in a little bit of a hurry. I would just blow until I noticed I was pushing snow and it was getting just a little higher than the top of the blower. I just left off the HST pedal (even on hills) and let the blower throw the snow piled up in front of it and then I would continue on. With a two stage clutch you would have to push the clutch half way in and step on the brake and then release both when ready to move again, not hard but still more work.
    With a single stage clutch I'm guessing you would have to stop and back up if you overloaded the blower or be careful not to do it to begin with. Maybe someone else could answer how best to do it.
    I run my engine usually around 2000 rpm but with less HP I would expect you'll want to be running at full PTO speed. On the specs listed the gear tractor that means you will be doing .8mph. If you get big snow falls and/ or heavy wet snow that could be too fast. If so you run into what I was talking about above.
    Can you do it, yes a gear tractor will run a snow blower. They have been doing it for decades. It will mean extra work on your part, only you can decide what's right.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer
  9. #9
    RFB
    RFB is online now
    Join Date
    Jan 2006
    Posts
    871
    West Central Idaho
    As I mentioned, if I were performing ground engagement ag duties, then that changes the paradigm and I would defer to a power shuttle geared system.
    One of the issues in play here is something that I tried to reference in my first post. I have spent time in PA (Poconos), the middle Atlantic (southern New Jersey) region, and Arkansas (Mountain Home) and the snow conditions there are what I would describe as light to maybe bordering on moderate in the Poconos.
    My frame of reference is different. Our average here is around 200 inches (at the lower elevations) starting late November until mid-March- early April. In the higher elevations, there will still be several feet left until late July, early August.
    A foot of snow is something of a distraction that occurs during the breakfast hour; 6 inches is something you kick out of the way.
    Attached Thumbnails Attached Thumbnails New information on Hydro vs. Manual trans for snow blower use.-snow.jpg
  10. #10
    Join Date
    Nov 2001
    Posts
    15,684
    Bethel, Vermont
    Scaper,
    He meant a new post with new information on the tractor he was considering...not that HST was new.
    However, it would have been better if he'd just posted the update on the original thread (easier to follow).
    Roy Jackson
Similar Threads
  1. Hydro trans operation?
    By gkk2001 in forum Buying/Pricing/Comparisons
    Last Post: 06-08-2003, 12:07 PM
  2. my new tractor- manual vs hydro
    By BWS in forum Buying/Pricing/Comparisons
    Last Post: 12-20-2002, 02:42 PM
  3. Adding Trans Hydro Fluid
    By jray in forum Grey Market Tractors
    Last Post: 09-20-2002, 10:44 PM
  4. Hydro Trans Question?
    By bnixon in forum Owning/Operating
    Last Post: 07-02-2002, 05:19 AM
  5. Hydro vs Gear Trans?
    By MattCole in forum John Deere Owning/Operating
    Last Post: 11-28-2001, 08:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
