4shorts
Elite Member
Good post 4shorts. I think a person could debate the merits of floating the plow vs floating the loader....and hard surface vs gravel use.....for a looong time. I struggled with which way to build my FEL plow until thinking it through.
There may be no right answer for everyone or every situation. The logic in my build is to keep the plow as lightweight as practical and use the slit-tube to provide the float. I'm not certain if less weight will scrape less dirt and gravel....but I'd like to believe it's better for my needs than more weight riding on shoes over my rough ground....and that is how these plows were designed to operate.
I think that if I had pavement to plow I would have skid shoes and float the loader as you do....to take advantage of extra weight and down pressure with the loader.
I think it's a basic decision a FEL plow builder has to make. However....if I change my mind after using my set-up......it could easily be converted to make the plow rigid with the frame and then float the loader as you do. Either way....it's still compact with the tractor.
Thanks. I operated heavy equipment for many years before doing what I do now. That blade you see in my original thread was used on my pick up for 13 years and the one gripe I had with it was the fact it had no down pressure and using it there were times it would ride up over the snow because of the stupid chain that was on it. When that would happen the truck would get stuck in the snow.
Now guys will report that my design will work well with your FEL in the float position and they are only partly right. The float will be ok to use straight but use the float while turning and you just won't turn. You'll need to apply just enough down pressure and you'll have full control of the steering of the tractor.
One thing I do like about my system is when I have the four skids on the ground plowing and I decide I want to scrape all I need to do is tilt my blade, bring the rear shoes off the ground a inch or so and the cutting edge does the job. It makes the blade more useful than if it had just the chain.
You are right. Everyone will have there own opinion but I think as time goes on and you use your design you will end removing the pipe, install the four pads ( two front,two rear) and have your plow attached solid so that you'll have down pressure.
Your also right. It's an easy fix to add these items and you might get by just fine as it is. I've got two hundred hours using mine commercially and there's nothing I would change on it. I have used it on some gravel driveways and the skids work very well on that surface as well.
