Results 11 to 20 of 22
11-18-2011, 07:34 PM #11Elite Member
- Join Date
- Sep 2008
- Posts
- 2,840
- Location
- NE USA
- Tractor
- JD LA115, WH 244, WH 525 hydro-pops,Original Troy Built Horse 8 HP
Re: Farm King 740 snow blower
Ask and you shall receive, Clarence has kits for both the walk behinds and the rear and front mount snow casters. the buyers of them rave about how well the old snow casters work with the impeller kits.
Both sizes are the same price or were anyway, I cannot use one on my John deere because of the plastic impeller, UGH!!!!!!!!!!, we will see how it fairs this winter...
The link is not working again for some reason&^%^%, but if you google clarences impeller kit it will bring you right to it on the first page.
11-18-2011, 08:33 PM #12
currently own
2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
Quick Attach 79" loader mount snowblower & rear powerpack
Quick Attach 84" Snow Blade
Quick Attach 42" pallet forks
11-19-2011, 08:15 PM #13Elite Member
- Join Date
- Sep 2008
- Posts
- 2,840
- Location
- NE USA
- Tractor
I have thread here in on the attachment forum descrbing how you can install a screen guard/reinforcing mesh screen to the front of the snow caster to prevent large rocks and the like from entering the mounted snow caster.
The large mesh and the narrow flat steel used to secure it wil not hamper the snow removal process and you can always pull forward and take half a cut if desired and it saves on damage with broken shear pins as the snow mounds up in front if you are traveling too fast anyway which creates a lot of excess strain on the impeller as the amount of snow entering the snow caster is not regulated.
03-07-2013, 05:32 PM #14New Member
- Join Date
- Mar 2013
- Posts
- 2
- Location
- Jordan, MN
- Tractor
- John Deere 4610
Can you explain to me how to replace the auger shear bolt? I can't seem to figure it out.
Thanks much.
03-07-2013, 05:33 PM #15New Member
- Join Date
- Mar 2013
- Posts
- 2
- Location
- Jordan, MN
- Tractor
- John Deere 4610
Can you explain how to replace the auger shear bolt. I can't seem to figure it out. Does the sprocket and bearing have to be removed first?
03-07-2013, 06:14 PM #16Member
- Join Date
- Jan 2011
- Posts
- 34
- Location
- Baldwin, MI
- Tractor
- NH TC35D
The auger shear bolt is located by the small sprocket that the chain is on. If you rotate the auger (usually best to have someone else rotate it while you look) you will see 2 circular plates and a small hole for the bolt to go through. you have to line up the 2 plates and holes to get the bolt in. I attached a pic- look at the yellow arrow but it will be under the metal cap which you don't need to remove. Hope that makes sense but if it doesn't let me know and I can take a picture of exactly where it is.
2003 New Holland TC35D 4x4 w/FEL
Farm King Y740 snow blower
Wildkat root grapple
6' box blade
7' landscape rake
hay spear
03-07-2013, 06:19 PM #17Member
- Join Date
- Jan 2011
- Posts
- 34
- Location
- Baldwin, MI
- Tractor
- NH TC35D
To answer your other questions- no- nothing needs to be removed to replace the auger shear bolt. To replace the 2 prop shaft shear bolts you will need to take the driveshaft off but thats easy as well.
6' box blade
7' landscape rake
hay spear
03-09-2013, 12:30 AM #18Bronze Member
- Join Date
- Sep 2012
- Posts
- 69
- Location
- Kiowa, co
- Tractor
- Kioti RX6010 FEL, Yanmar snow blower 7' xtrreme rear blade
Sidewinder.... looking at a Farmking740 3pt snow blower. Do you like yours and would you buy one again?
Thanks,
03-10-2013, 10:51 PM #19Member
- Join Date
- Jan 2011
- Posts
- 34
- Location
- Baldwin, MI
- Tractor
- NH TC35D
So far I've been very happy with it and I'd buy it again. I wish the clearance between the impellor and housing were a little closer but that's the only complaint I have about it. I would also say definately get the hydraulic chute rotator as it would be a real pain for me without it.
6' box blade
7' landscape rake
hay spear
03-12-2013, 12:12 AM #20Bronze Member
- Join Date
- Sep 2012
- Posts
- 69
- Location
- Kiowa, co
- Tractor
Thanks for the info. I'm pricing one with the hydraulic chute rotator.
Similar Threads
How good is the 54 Snow Blower with Plastic Impeller
By 70stang in forum John Deere Buying/PricingReplies: 22Last Post: 03-22-2011, 11:19 AM -
Snowblower Measured how? / Testing working order?
By KewlTracks in forum AttachmentsReplies: 9Last Post: 01-16-2011, 11:45 PM -
Snow Front Snow Blower or Front Snow Plow?
By FRIZ in forum John Deere Owning/OperatingReplies: 13Last Post: 05-23-2009, 10:38 AM -
Snow Snow blower and engine RPM question
By easygo in forum Kubota Owning/OperatingReplies: 13Last Post: 02-04-2009, 03:40 PM -
How much power to run a 5' snow blower
By tessiers in forum Build-It YourselfReplies: 13Last Post: 05-30-2008, 07:57 PM
