Results 21 to 22 of 22
03-12-2013, 10:20 AM #21Member
- Join Date
- Jan 2011
- Posts
- 34
- Location
- Baldwin, MI
- Tractor
- NH TC35D
Re: Farm King 740 snow blower
Good luck with the purchase. I also forgot to mention that I installed a pipe on the cutting edge since I have a gravel driveway and it made a huge difference. I used a piece of 2.5" galvanized pipe (used for power feed conduit almost 1/4" thick) and split it lengthwise. I welded some tabs to it and it slips over the cutting edge and is bolted in place with 2 bolts for easy removal once the ground is frozen. Since I split the pipe it only has about 1" below the cutting edge but having the rounded cutting edge made all the difference for me. No more picking up gravel and rocks. I've only broken 2 shear pins and that was due to picking up pieces of wood that fell from trees during the snow storm and couldn't see them. I will say it likes deeper snow better- I prefer to wait till there is 8" or more if possible as it seems to do a better job with more snow. some areas I've waited till there was over a foot and it goes through it like butter.
2003 New Holland TC35D 4x4 w/FEL
Farm King Y740 snow blower
Wildkat root grapple
6' box blade
7' landscape rake
hay spear
03-13-2013, 11:45 PM #22Gold Member
- Join Date
- Jul 2008
- Posts
- 340
- Location
- Wisconsin
- Tractor
- John Deere 3520, John Deere X749
I have a slightly older version that was already set up for hydraulic chute rotation and all I had to do was add a cylinder. I also modified the chute a bit and put on a hydraulic chute deflector with a spare cylinder I had. Great Idea with the pipe this is one of my biggest problems. could you post a picture or two of the pipe.
Similar Threads
How good is the 54 Snow Blower with Plastic Impeller
By 70stang in forum John Deere Buying/PricingReplies: 22Last Post: 03-22-2011, 11:19 AM -
Snowblower Measured how? / Testing working order?
By KewlTracks in forum AttachmentsReplies: 9Last Post: 01-16-2011, 11:45 PM -
Snow Front Snow Blower or Front Snow Plow?
By FRIZ in forum John Deere Owning/OperatingReplies: 13Last Post: 05-23-2009, 10:38 AM -
Snow Snow blower and engine RPM question
By easygo in forum Kubota Owning/OperatingReplies: 13Last Post: 02-04-2009, 03:40 PM -
How much power to run a 5' snow blower
By tessiers in forum Build-It YourselfReplies: 13Last Post: 05-30-2008, 07:57 PM
