Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Member
    Join Date
    Jan 2011
    Posts
    34
    Baldwin, MI
    NH TC35D
    Default Farm King 740 snow blower
    First I have to thank everyone on this forum. I've been reading a lot about snow blowers for a while now and have learned quite a bit. I was pretty sure I was going to get a front mount blower but just couldn't get over the fact that I wouldn't be able to use my FEL. So I looked at rear 3pt blowers and I looked at a lot- Buhler/Farm King, woods, New Holland, JD, Meteor, Pronovost, etc. I was actually pretty set on getting a Lorenz. Ended up driving by a NH dealer I have never been to and figured I'd see what they had in stock. Ended up going home with this Farm King Y740. It's last years model and had been on there lot for a while so they made me a smokin deal I just couldn't pass up. Something tells me it was priced wrong or something but ended up getting it for just over $2300 after tax with the Hyd chute. Seems to be built very well and it's pretty heavy. Hopefully my TC35 handles it well. I think I'm ready for the snow now!
    2003 New Holland TC35D 4x4 w/FEL
    Farm King Y740 snow blower
    Wildkat root grapple
    6' box blade
    7' landscape rake
    hay spear
  2. #2
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,162
    north idaho
    Kioti DK45SE hst cab
    Default Re: Farm King 740 snow blower
    I had a farmking blower for about 6 seasons. they work great. The only issue i had with mine was i bent the augar several times on hidden rocks (we grow rocks in N. Idaho... i kid you not. they show up in the middle of my lawn every year...large rocks). I ended up having to weld a few support plates on the auger and this stopped all further trouble. Also learned not to use too strong of a shear bolt. The blower worked best after the ground was good and frozen. Congrats.
    Mine had hyd chute rotator also...worth every penny.
    Attached Thumbnails Attached Thumbnails Farm King 740 snow blower-rotor-fix-jpg
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  3. #3
    Platinum Member bubbacuse77's Avatar
    Join Date
    Jul 2008
    Posts
    575
    Wisconsin
    John Deere 3520, John Deere X749
    I have the same blower just a few models older, built like a tank and replacement parts are standard farm parts that can be found at any farm store. You won't be disappointed.
  4. #4
    Join Date
    Jan 2011
    Posts
    7,162
    north idaho
    oh... and get a stock of both sizes of shear pins before the snow flies. Replacing the 2 in the PTO shaft really sucks..the other one on the chain drive is real easy.
    currently own
  5. #5
    Elite Member foggy1111's Avatar
    Join Date
    Dec 2008
    Posts
    2,534
    Nisswa, MN
    JD 3320 eHydro w/ 300CX Loader
    Sounds like a good deal on a good plow! Your all set.
    Wonder if you got skid shoes for that nice gravel driveway? Cant tell from the pictures. Something to consider.
    Edit: One more look at your pics....and I saw the shoes. WTG
    3320 eHydro, 300CX Loader & 15 + great attachments
    You gotta mine allot of dirt to find a diamond.
  6. #6
    Elite Member
    Join Date
    Sep 2008
    Posts
    4,800
    NE USA
    JD LA115, WH 244, Troy Built Horse 8 HP
    Wink Re: Farm King 740 snow blower
    Quote Originally Posted by sidewinder770 View Post
    All you need now is one of clarences impeller kits to sweep the impeller drum clean and cast the snow about 50 feet. the impeller kit costs thrty dollars and clarence has a money back guarantee if you do not like the kit.
    Clarence has a very happy bunch of of customers anf he has a you tube video showing how well the impeller kit works.
    All you need now is a few cans of Fluid Film? | Corrosion Preventative, Lubricant and Rust Inhibitor for the chute and spout to keep the snow from sticking
  7. #7
    Member
    Join Date
    Jan 2011
    Posts
    34
    Baldwin, MI
    NH TC35D
    Quote Originally Posted by grsthegreat View Post
    I thought the same thing when I was at the dealer. I asked if they had some and they said sure- we'll give ya a few at no cost. They walked out and handed me 6 - 1-1/4"x1/4" bolts. I did notice that there were 2 extras in with the manual but they both looked the same. I'll have to go check and make sure of the location and how to replace before I start blowing with it. Probably should pick up a few extras as well- no rocks here but frozen horse road apples might as well be the same thing . I'll have to look at getting another set of rear remotes as well so I can use the hyd top link with the blower but maybe I won't need to ?
    6' box blade
    7' landscape rake
    hay spear
  8. #8
    Member
    Join Date
    Jan 2011
    Posts
    34
    Baldwin, MI
    NH TC35D
    Quote Originally Posted by leonz View Post
    I did get a few cans of fluid film but no impleller kit. I've heard them mentioned a few times on this site but haven't seen any links for a website. Does anyone have a link for that or does he not have a website to order from? Might get a kit for my walk behind blower as well.
    6' box blade
    7' landscape rake
    hay spear
  9. #9
    Join Date
    Jan 2011
    Posts
    7,162
    north idaho
    there are 2 large shear bolts on the tractor side of the PTO and one smaller shear bolt on the chain pully (off of the drive shaft). I forget the size and shear strength though. it is specified in the manual as to size and grade. The only way the pto shears is if something gets cought in the impellers directly. Rocks have a way of sneaking in there.
    currently own
  10. #10
    Veteran Member wedge40's Avatar
    Join Date
    Oct 2007
    Posts
    2,216
    I dont have snow blower, but since most snow if pretty "fluffy" would it be worth while to put some sort of screen mesh over the front. Or at least up 6 or 8 inches to stop the rocks. I know there is potential for it to get blocked up, but if rocks are the major cause of shear pin breakage then this might help.
    Wedge
    PS It's early and I haven't have had my coffee.
    1967 Ford 4000,Mahindra 4530 with FEL and BH, Box blade, straight blade, FEL, Rake, Bushhog, Backhoe, Jinma chipper, KKII tiller, Grapple. Mahindra 4530, with FEL and Backhoe.
Similar Threads
  1. How much power to run a 5' snow blower
    By tessiers in forum Build-It Yourself
    Last Post: 01-12-2014, 07:54 PM
  2. How good is the 54 Snow Blower with Plastic Impeller
    By 70stang in forum John Deere Buying/Pricing
    Last Post: 03-22-2011, 11:19 AM
  3. Snowblower Measured how? / Testing working order?
    By KewlTracks in forum Attachments
    Last Post: 01-16-2011, 11:45 PM
  4. Snow Front Snow Blower or Front Snow Plow?
    By FRIZ in forum John Deere Owning/Operating
    Last Post: 05-23-2009, 10:38 AM
  5. Snow Snow blower and engine RPM question
    By easygo in forum Kubota Owning/Operating
    Last Post: 02-04-2009, 03:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
