Results 1 to 10 of 24
11-25-2011, 08:55 PM #1Member
- Join Date
- Aug 2007
- Posts
- 25
- Location
- New Vineyard, Maine
- Tractor
- Kioti DK45SC
caster wheels on plow
looking for some input on an idea i have for my plow, i want to mount heavy duty caster wheel with adjustable washers like the shoes. it seems to me they would work better than shoes, which gouge the ground. You can keep the plow an inch off the ground for plowing gravel roads and the plow would roll? ive seen them on larger plows. mine is a western 10 ft that was made into a 12ft, on a 1984 C-70., so its heavy and rips up my road until the ground freezes. any ideas? or pics
11-26-2011, 07:59 AM #2
Re: caster wheels on plow
Do a search on wheels in this forum or gauge wheels in general and you will find lots of information on plowing gravel drives.
My FEL plow isn't as nearly as big as yours, but the shoes don't work well on unfrozen ground. I continue to look for a better solution, so will be interested in what you come up with.Barry
Lawson Hill Farm
NH TC40DA
'64 IH Cub Lo-Boy
'47 Willys Jeep CJ2a w/ PTO
'49 Willys Jeep CJ3a w/ PTO & 3pt lift
http://www.farmjeep.com/
11-26-2011, 12:32 PM #3Elite Member
- Join Date
- Sep 2008
- Posts
- 2,846
- Location
- NE USA
- Tractor
- JD LA115, WH 244, WH 525 hydro-pops,Original Troy Built Horse 8 HP
You can purchase pneumatic casters from Mcmaster Carr and use some angle iron to attach them to the plow.
11-26-2011, 08:23 PM #4Elite Member
- Join Date
- Oct 2006
- Posts
- 3,243
- Location
- N.E., Ohio
- Tractor
- GC2310, Toro Reelmaster 5100D
That is exactly what I did, years ago.
I can adjust the height by raising or lowering the FEL slightly. I can even put the blade down on to the ground when I plow a paved drive, by tilting it.
You should also add a Pipe to the bottom of the plow, this will also keep the edge from digging in.
If you weld a couple of tabs on a piece of steel pipe, (I used 1 1/2" pipe), you can bolt it to the bottom of the blade. (Use the bolt holes that hold the cutting edge on the plow). Don't waste your time cutting a slot in the pipe so it will fit over the the cutting edge, It is totally unnecessary.
This all works best if you pack down the first 3-4 inches of snow. Then, you can pretty much plow it all you want, and not move any gravel.
11-26-2011, 08:34 PM #5Member
- Join Date
- Aug 2007
- Posts
- 25
- Location
- Tractor
- Kioti DK45SC
nice set up, i was hoping someone out there did this already, i was thinking of mounting the casters to a plate with a steel rod using the shoe mount hole with washers..thanks for the input and pics
11-26-2011, 08:44 PM #6Elite Member
- Join Date
- Oct 2006
- Posts
- 3,243
- Location
- N.E., Ohio
- Tractor
11-26-2011, 08:59 PM #7
Gary
JD 4520, 400X FEL, Frontier Front Blade, Box Blade, Rotary Cutter, Landscape Rake, 48" Wildkat Grapple and PHD
11-27-2011, 09:03 AM #8Elite Member
- Join Date
- Oct 2006
- Posts
- 3,243
- Location
- N.E., Ohio
- Tractor
I just remembered this site has some photo's of HD plows with casters: RT Reversible Trip Blade Snow Plow
11-27-2011, 09:54 PM #9Member
- Join Date
- Aug 2007
- Posts
- 25
- Location
- Tractor
- Kioti DK45SC
for Maine lobsters its best to look online for the best price, most places will ship anywhere.
11-27-2011, 09:56 PM #10Member
- Join Date
- Aug 2007
- Posts
- 25
- Location
- Tractor
- Kioti DK45SC
yes caster wheel like that or similar. how come the common pick up plow manufactures like fisher dont make a wheel kit using the same hole as the shoes? im still on the hunt for the right set up. thanks
Similar Threads
Plow cutter wheels ?
By ticolawnllc in forum AttachmentsReplies: 1Last Post: 11-14-2011, 01:21 PM -
Front or Rear Snow Blower?
By marxman in forum Snow RemovalReplies: 32Last Post: 07-15-2011, 09:21 PM -
10-152 Ford plow
By MoKioti in forum AttachmentsReplies: 6Last Post: 11-17-2008, 10:11 AM -
MF Bottom Plow?
By sunspot in forum AttachmentsReplies: 3Last Post: 09-30-2007, 01:37 AM -
Finish mower caster wheels
By Mosey in forum AttachmentsReplies: 1Last Post: 01-08-2002, 11:58 AM
