Hope this works!
   / Hope this works! #1
GregbkH
Gold Member
Wisconsin
2010 New Holland 3045
I'm a relatively new tractor owner. In June of this year I purchased a Boomer 3045 with backhoe and a Land Pride rear blade. After reading many threads on here, I added skid shoes and a pipe to the edge of my rear blade. I have about 550' of gravel drive at my place and have never plowed snow with a rear blade before. Do you think this will work? Thanks.
   / Hope this works! #2
I've used a pipe for 22 years and I know it works. I doubt you need the skid shoes.
   / Hope this works! #4
I agree, with the pipe I doubt that the skid shoes will be needed, but when the snow and ice are gone, they will be great for grading the drive. :thumbsup:
   / Hope this works! #5
I actually did better in my gravel drive days, 280' but 40' wide, with the 7' Woods Rear Grader Blade backwars and then angled off to the side. It was heavy enough to move the snow but left the gravel in place for the most part. Now that I have it paved its a breeze with my current setup, a 7' Meyer Snow Plow and the grader blade. See avatar.
Chris
   / Hope this works! #7
I think you'll do fine, although you may want to look at chains and something to keep the bucket off the ground if you need to use it. The rear blade will try to swing the tractor around if you angle it much in deep snow.
I find mine's ok for up to about 10 inches of snow, beyond that it calls for punching through with the bucket first.
I built a screen to keep snow from spilling back over the bucket, and skids to keep the bucket from scooping any gravel.
   / Hope this works! #8
Chilly807, I just have to bug you about this again. :laughing: You paint your bucket after the modifications, ( which look great by the way) but you leave your rear blade primer grey. You really need to paint it either black (what the OEM color would be) or at least Kubota orange. ;)
   / Hope this works! #10
Brian,
You'll be glad to hear I repainted it yesterday for the winter season. It was worn off from a summer of moving rock and soil, and the first snow we had stuck pretty badly.
Oh, did I mention I found some more grey paint? ;)
Sean
72" Hydraulic Broom  (A52384)
72" Hydraulic...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A53472)
2022 Down2Earth...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
