radioman
Super Member
I had a plow with manual angle adjustment, and I changed the angle occasionally. then I upgraded and my plow has hydrualic angle adjustment and I use it all the time. I'm much more productive with it. There's no way I could plow with no angle adjustment.
I agree. If all you are doing is your own driveway, quite often manual angle is all you need. You just figure out what fits best for you to push snow to one side all the time.
l'm slowly working towards putting an old truck plow on in place of the bucket on the front loader. It can be angled using the hydraulic cylinders or manually if I pulled them off. I'm on the fence about tilt, talk me into or out of it... I currently have another light blade clamp mounted to the bucket, so it sits farther out front, and I can't use tilt without losing steering on the front end even with chains. I don't have a spare hydraulic, so that's another bridge to cross.
I know exactly what you are talking about. I did the same with my tractor. At first I mounted plow moldboard directly without a frame to FEL arms, no angle. It works ok, but I really needed angle plowing to push deeper stuff and less spillage. I finally added brackets to A frame and used angle plowing. AHHHH much better. It was a thousand time better plowing.
If I were you, I'd use a pin to pock plow to angle and go from there. If after one winter its such a hassle, then go ahead add a divertor from curl circuit for power angling.
