Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
  1. #21
    Join Date
    Jan 2006
    Posts
    963
    West Central Idaho
    Kubota L5740HSTC3; B3000HSDCC
    Default
    Mr. Fowler,
    Yes, I did comprehend that and was trying to ensure that my meaning (not yours) was not confusing to the OP.
  2. #22
    Veteran Member JoelD's Avatar
    Join Date
    Jan 2005
    Posts
    2,129
    Windham, NH and York, ME
    Kioti LK3054xs TLB, 2004
    Default Re: I want to hear from owners of Kubota front mount blowers
    Sorry catfish, did not realize your superior knowledge of forums.
    My bad.
    Will be sure to stay clear of responding to such posts, wouldn't want to "make a forum mistake".
    I guess you get the specificity of response equal to the dollars you spent in the request.
    Joel
    Joel
    2004 Kioti LK3054XS TLB
    Woods Box Blade
    King Cutter Tiller
    Three Point Snow Blower
    York rake
    60 inch king kutter tiller
    2000 Dodge Durango 5.9
  3. #23
    Veteran Member smfcpacfp's Avatar
    Join Date
    Nov 2007
    Posts
    1,346
    Sands Township, Marquette Co, Michigan
    Kubota B3030HSDC
    I also have the B3030 HSDC and agree with nfowler generally.
    1. You need to remove the subframe if you are going to use the FEL effectively. In my case changeover isn't an issue because we get a lot of snow which covers the ground to a thickness of 5 feet of very dense snow/ice by the end of the year, so I have no use for the FEL in the winter. With a helper it takes an hour or two to get the FEL off and the blower and subframe on. Since I make the change so seldom (once a year), it takes me a while to remember what to do. It looks like the B3030 replacement (B3000) doesn't have that issue. If you need to use both in the winter, obviously that would be an issue.
    2. Non issue for me
    3. My comfort is worth the front blower. I have yet to hear anyone with a snowblower say they prefer the comfort and ease of use of a rear blower over the front blower. It's usually, "I wish I had got the front blower, or my next blower will be a front blower." I don't plan on getting another rig. I always get exactly what I want to avoid the shoulda's. At almost 65 this should do me for my forever.
    4. Yes but probable a larger tractor just because I like bigger. My friend who owns a motorcycle/snowmobile dealership has a 47 hp Grand L which is such a nice big rig, both inside and outside. The snowblower on that has metal twice as thick as mine - what a beast. He only uses it for snowblowing shockingly. It isn't any faster than mine - really tremendous overkill for the task. I used it one day for him at my request. It only cost $15,000 more than mine.
  4. #24
    Veteran Member kevinj's Avatar
    Join Date
    Jul 2003
    Posts
    1,380
    West MI
    BX-1860, L3940HSTC, B7500, Farmall M, Farmall 560D
    Quote Originally Posted by Catfish Man View Post
    I suspect I'm being fed bad information from a dealer. He either is not very knowledgeable about the products he sells or he wants to talk me into equipment he already has in inventory so he doesn't get stuck with it in the off season.
    I routinely ask questions that I already know the answer to. This tells me if I can trust the person that I'm dealing with (I learned this years ago dealing with cars). This guy didn't pass my test, so I don't trust him, but he did plant some doubt in my mind.
    So I have a few questions:
    1. Do you have to remove the snow blower subframe to mount the front end loader?
    2. Do you feel the blower subframe is in your way when doing other tasks, (bush-hogging, road grading etc)
    3. Do you feel the front mount blower is worth the extra money over the rear?
    4. If your tractor and blower was stolen, would you replace it with another kubota front mount?
    1. best to remove it
    2. see #1
    3. absolutely, see my sig.
    4. absolutely again
    you did not list your tractor, that makes a huge difference in the subframe, see my sig, I have 2 different styles
    Kevin
    BX1860, mower, snowblower - B7500HST, FEL, Bush Hog - Grand L3940 HSTC, FEL, snowblower, 6' Landpride brush hog, 6' King Kutter tiller, Corn Pro 18+5 Fifth Wheel, 1950 Farmall M, Farmall 560D
  5. #25
    Silver Member Catfish Man's Avatar
    Join Date
    Feb 2012
    Posts
    178
    West Virginia
    I haven't made a purchase yet, but if I go front mount it will be on a grand L 4240
  6. #26
    Join Date
    Jul 2003
    Posts
    1,380
    West MI
    i hope you mean grand L4240hstc for a snowblower
    Kevin
  7. #27
    Join Date
    Feb 2012
    Posts
    178
    West Virginia
    Quote Originally Posted by kevinj View Post
    yep that's what I meant
  8. #28
    Join Date
    Jul 2003
    Posts
    1,380
    West MI
    Have you not seen one of these up close???
    That subframe is a beast with about 6" clearance and can impede loader operation.
    Unless you need the FEL a lot in the winter the blower is a far superior snow removal tool.
    Due to dealer error I ended up with the 3rd Function so I added a hydraulic flipper.
    Attached Thumbnails Attached Thumbnails I want to hear from owners of Kubota front mount blowers-p1220009-jpg   I want to hear from owners of Kubota front mount blowers-blower-hyd-mod-2-jpg
    Kevin
  9. #29
    Join Date
    Feb 2012
    Posts
    178
    West Virginia
    i've been looking at the tractors, but none of the dealers i have visited have a front mount already mounted to an L series, I've seen them in person on the B series.
    thanks for the pictures
  10. #30
    Join Date
    Jul 2003
    Posts
    1,380
    West MI
    The frame is easy off and on within reason. It goes to the back and anchors to the draw bar with center and front mounts. It does not require tools however.
    Kevin
Similar Threads
  1. Ford 800 hard steering to left
    By george46 in forum Parts/Repairs
    Last Post: 05-31-2017, 11:15 AM
  2. Snowblower Front end mount used on hardpack driveway
    By NHTC40D in forum Attachments
    Last Post: 05-19-2011, 08:16 PM
  3. Snow front mount snowblower on the kubota
    By stratton in forum Kubota Owning/Operating
    Last Post: 01-23-2011, 04:10 PM
  4. Can You Defend Kubota Corporation....
    By Junkman in forum Kubota Owning/Operating
    Last Post: 07-16-2010, 02:35 PM
  5. TC55 Steering Problems Fixed?
    By mundamanu in forum New Holland Buying/Pricing
    Last Post: 10-25-2006, 08:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
