DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,227
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
Although it is a front mounted blade, you could make the same thing for the 3pt. one.
I slit a piece of 1-1/4" steel pipe to slip over the bottom of the blade and welded tabs on to bolt it on.
So far, it has worked great, because we haven't had enough snow to warrant using it. If I had known it would work that good, I'd have done it years ago....!!
