Results 11 to 20 of 25
07-24-2012, 09:56 PM #11
Re: Another QA plow build thread. (Need help)
Well if it works for you, I can't argue. I would think it would be easier to put a new one in, but that's me. This project finally drove me to get a cutting torch, and that helps with stuff like this a ton.
I drove the pins on mine inward slightly before driving them out. Easier to break the rust that way as access from the outside was a lot better, as you know. Then it came out with reasonable blows of the hammer with a bolt as a drift/punch in the hole.
BTW - What part of WNY are you in? I grew up in Jamestown.-Dave
"Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
L3130HST, QA, 723 Loader, 48" Forks, 48" Grapple, Ancient Farmi Skidding winch
Trailer - 10k/16' twin axle w/elec brakes
2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
07-24-2012, 10:49 PM #12Elite Member
- Join Date
- Feb 2011
- Posts
- 3,800
- Location
- NOT HERE
- Tractor
07-25-2012, 06:13 AM #13Bronze Member
- Join Date
- Nov 2011
- Posts
- 90
- Location
- Western NY
- Tractor
- Mahindra 4035
07-29-2012, 07:53 PM #14Bronze Member
- Join Date
- Nov 2011
- Posts
- 90
- Location
- Western NY
- Tractor
- Mahindra 4035
I had a few hours to work today, and got the mount frame tacked together and on the QA plate, and mounted it on the tractor to verify that everything works. I'll be adding several brackets and reinforcements, tabs underneath for actually mounting the plow frame, and I need to figure out a way to attach the chain to the QA plate, then it should be ready for painting.
07-29-2012, 08:55 PM #15Bronze Member
- Join Date
- Apr 2011
- Posts
- 75
- Location
- maryland
- Tractor
- kubota g2460 Kubota L4330
you can weld a piece of steel with a groove cut in it for the chain. Adjustments in length are easy.
07-29-2012, 09:34 PM #16Bronze Member
- Join Date
- Nov 2011
- Posts
- 90
- Location
- Western NY
- Tractor
- Mahindra 4035
08-05-2012, 06:59 PM #17Bronze Member
- Join Date
- Nov 2011
- Posts
- 90
- Location
- Western NY
- Tractor
- Mahindra 4035
Update 8/5. I finished welding up the basic frame today and added the tabs for connecting the plow. I will be adding reinforcement, braces and gussets in several locations yet before it gets cleaned and primed. I don't have the hydraulics on yet, the x-over valve, various adapters and hoses will be here tomorrow. Here are some pictures.
08-06-2012, 09:01 PM #18Elite Member
- Join Date
- Feb 2011
- Posts
- 3,800
- Location
- NOT HERE
- Tractor
It looks good. i like how close you have it positioned to the tractor. Did you say you were going to put ski shoes under the back too?
08-07-2012, 09:09 AM #19Bronze Member
- Join Date
- Nov 2011
- Posts
- 90
- Location
- Western NY
- Tractor
- Mahindra 4035
08-08-2012, 12:23 AM #20
The reason I put shoes in the back was the same as 4Shorts - to prevent the back edge of the frame from digging in and gouging the driveway. If that is not a concern for you, then don't bother. I don't want to mess up a driveway when I can prevent it pretty easily this way. I just welded tubes that fit the shoes I picked up into the back corner of the a-frame.
-Dave
Similar Threads
New FEL plow build
By bubbacuse77 in forum AttachmentsReplies: 19Last Post: 11-19-2011, 07:12 PM -
Complete snow plow build
By 4440 in forum Build-It YourselfReplies: 12Last Post: 04-03-2010, 08:33 PM -
Yet another snow plow thread!
By 52wej in forum Build-It YourselfReplies: 3Last Post: 02-01-2010, 05:51 AM -
My plow mount thread...
By jd2305cd in forum Build-It YourselfReplies: 79Last Post: 01-29-2010, 07:14 PM -
Another Plow/QA Build One Catch it's On A TZ18
By silverado15000 in forum Build-It YourselfReplies: 4Last Post: 01-15-2010, 10:24 PM
