dstig1
Elite Member
- Joined
- Apr 7, 2010
- Messages
- 4,786
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
Thanks, Dave. As for hours... Well I bought the plow in early April....and finished it a couple weeks ago. You do the math Seriously I do not know other than "a lot". I am not good with a cutting torch and am not an ace welder by any stretch so that all takes far longer than it should for someone skilled in the arts. I did disassembly right away and cut off a few things I knew had to go. Ordered a bunch of parts in (there were hours there just finding things and then decent prices). Did some test fits and figured out how I was going to attach and brace the SSQA plate. Picked up steel. And a sandblaster. Torched off the moldboard and brought it in to get a new one made. Oh yeah - had to buy a torch for that... Blasted the frame parts. Repaired some of the bent up frame parts. Cut steel, fitted it, cut it some more fitted it some more, ad infinitum until I got it right (those angle braces are tricky with compound angles...). Finally tacked stuff up and primed. Did final welding after checking fits. More priming and finally paint and assembly. All that over 4 months. Probably somewhere north of 50-60 hrs, possibly way north... totally guessing.
IMO - The reason you aren't seeing people do the designs you show, is most everyone is adapting/refurbing a truck plow. The common ones are similar to mine, it seems. I also think that by adding the rear shoes, I all but eliminate risk to the cylinders. Anything is possible, but I believe the front and rear shoes should conspire to keep the frame off the ground.
