Page 2 of 7 FirstFirst 12345 ... LastLast
Results 11 to 20 of 63
  1. #11
    Silver Member droptop's Avatar
    Join Date
    Jan 2012
    Posts
    141
    Western NY
    Massey Ferguson 1635 cab
    Default Re: rear 3pt blower
    I had a 60" AgroTrend and just picked up a used 78" Lucknow to go with my new tractor. Both the AgroTrend and Lucknow are made in Canada and are well built units. The Lucknow is a real heavy beast at almost 900 lbs. I'm just waiting for the white stuff to try it.
  2. #12
    Join Date
    Jul 2003
    Posts
    222
    I picked up an old, but unused, 60" Allied/Buhler for $800 and it's worked fine with my B2150. It does not have skid shoes on it, but that has not caused any problems so far.
    It will throw the snow easily 20' away. BUT, it does depend on the "type" of snow. Wet and heavy is tougher, AND it will clog up the shoot quickly.
    I use an old broom handle to clear it.
    I had to call Buhler to get a copy of the manual for it, and they were really great to deal with on the phone and mailed me a photocopy of the manual.
    I actually talked to one of the Buhler family. He also sent me some extra shear bolts free of charge.
  3. #13
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    3,772
    SW Pa.
    Massey Ferguson GC2400
    Quote Originally Posted by TimP View Post
    That's a company to acknowledge on the forum.
    Thank You.
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  4. #14
    Platinum Member flyingcow's Avatar
    Join Date
    Jan 2010
    Posts
    974
    aroostook county maine
    I have run Lucknow's for a few yrs. No problem. Rugged,simple.. But i would love to have a Provost.
    TN75D, w/cab, FEL, BH
    7 1/2 ft Lucknow Blower
  5. #15
    Join Date
    Jan 2012
    Posts
    141
    Western NY
    I just saw a new Buhler at a dealer that had a 1/2" gap between the blower blades and the housing. My old AgroTrend only had a 1/8" gap and my current Lucknow is only slightly more. The smaller the gap, the better it works.
  6. #16
    Veteran Member bandit67's Avatar
    Join Date
    May 2004
    Posts
    1,539
    Foothills, Colorado
    B3000 HSDCC
    My new 60" Buhler has a 5/16" gap.
    2012 Kubota B3000, block heater, filled rears, rear wheel spacers, fender extensions, LA403 w/60" bucket, BH77 w/12" bucket & mechanical thumb, Kubota pin-type QA, Kubota forks, Caroni TM1600 flail, Buhler Allied YC6010 3pt blower, Meyer 72" FEL mounted plow, Midwest LR2072 rake
    Previous machines:
    2008 Kubota B3030 (Open Station), LA403, BH75, 4 - 55w halogen front & rear ROPS mounted worklights with L39 dash switches
    2004 Case NH DX24E Subcompact
    Kubotas from Barlow's
  7. #17
    Silver Member WinterDeere's Avatar
    Join Date
    Sep 2011
    Posts
    137
    Philadelphia
    John Deere 855
    Quote Originally Posted by flyingcow View Post
    Was just looking at the Provost blowers. What do you like about them? They seem mighty lightweight in all regards, only 413 lb. for 64" width. A 60" Woodmax weighs 650, due to heavier metal used all 'round.
  8. #18
    Gold Member SARG's Avatar
    Join Date
    Aug 2009
    Posts
    466
    Upstate New York
    NH T1030- 49G Brockway
    Tell ya one I would not recommend. That's the Meteor by KD Martin in Canada. I got a 51" a couple years ago and it uses a Superwinch LT2000 modified to rotate the chute. I just bought a new Superwinch brand from Amazon for $70.and modified it yesterday to fit. KD Martin wanted $270. for the same thing. I had to drill and tap four 5/16-18 holes to get the new one mounted.
    Now my friends who know about 4 wheeling and winches tell me the Superwinch brand is the bottom of the barrel ..... and if they corrode out after two years I guess they're right.
    And after tearing the Meteor Blower apart I now realize the Canadians seem to build like the Chinese. Tolerances don't seem to be part of the program ........ If it don't fit - Force it .... Seems to be the method used.
    $2300. I wish I could re-spend.
  9. #19
    Join Date
    Jan 2009
    Posts
    51
    Maine
    JD 3320 + cab + 300 CX FEL
    I had a Meteor 60 inch snowblower with manual rotation for over ten years never had a problem....bought a 75 inch model with hydraulic chute rotation about four years ago (due to the purchase of a larger tractor)...to date (knock on wood) I haven't had any problems. I have never had to deal with MK Martin (MK Martin Enterprise,Elmira Ontario) personally but I have heard from more than one person that they are very pleasant and eager to please. I checked out their website MK Martin | Meteor Snow Blowers and it seems that the only chute rotation they seem to offer is manual and hydraulic....after re-reading Sarg's post I see that the Superwinch was apparently a modification.
  10. #20
    kco
    kco is offline
    Join Date
    Jun 2004
    Posts
    657
    Armstrong, BC
    Kioti DK35 SE HST (2011)
    I've just had my MK Martin 75" pull-type snowblower one season but I'm happy with it and the build quality seems fine. Smaller blowers however may use lighter materials, so my opinion may not be relevant for them. Looking at last year's brochures for the pull-type blowers I see the 68" weighs 506# while the 75" weighs 748".
    As bennatti states, the new blowers use a hydraulic motor for the chute rotator for an additional $469. Perhaps they changed to hydraulic from winch and cable due to a poor service record. Of course it may have not been so bad if they had used a better quality winch motor.
    I did a lot of research before deciding on the MK Martin Meteor. My first choice would have been the more substantial Erskine (made in Minnesota I think) which weighs in at 1,050# for the 78" model pull-type. But it significantly more expensive than the lighter Meteor and I couldn't justify (and afford) the extra cost for my conditions, which aren't too demanding. Another brand that is a step up (I think) is Normand.
    As someone stated in this thread Lucknow was another that I closely considered for my conditions and price. I may have gone for it except the dealer said Lucknow's shipping price was $1,000 to be reviewed at the time of delivery. I got the Meteor with free delivery because it was combined with the dealer's larger shipment.
    I did call MK Martin while doing my research and found them very helpful.
    Again, I've just got 1 year on the Meteor and I'm happy with it. If it falls apart in a couple of years I'll change my tune. But I don't think it will give non operator-caused problems.
Similar Threads
  1. Replies: 33
    Last Post: 12-16-2012, 06:10 PM
  2. 3pt blower
    By Jay4200 in forum Build-It Yourself
    Last Post: 10-27-2011, 02:32 PM
  3. Snow Size of 3pt blower
    By Scaper in forum Kubota Owning/Operating
    Last Post: 12-28-2010, 02:30 PM
  4. Replies: 8
    Last Post: 09-08-2010, 02:52 PM
  5. Snow 3pt snow blower
    By pathman in forum Massey Ferguson Owning/Operating
    Last Post: 09-09-2008, 06:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
