Page 5 of 5 FirstFirst ... 2345
Results 41 to 43 of 43
  1. #41
    New Member
    Join Date
    Jun 2013
    Posts
    2
    Default Re: Boss Plow Quick-Attach Adapter
    No but where would I go to get one?? Also what would I do with the loader arms so there not in the way?
  2. #42
    Platinum Member catdozer's Avatar
    Join Date
    Sep 2011
    Posts
    508
    Indiana
    Bobcat CT235
    Default
    Quote Originally Posted by Electro View Post
    You would have to make a custom bracket yourself or by someone. You can take the arms off. I've seen Boss v-plows frame mounted on tractors and work amazing!
    Bobcat CT235 with Deere Imatch, And a very bad addiction of attachments
  3. #43
    Platinum Member Katahdin's Avatar
    Join Date
    Dec 2010
    Posts
    747
    Scarborough, ME
    Yanmar LX4500, Toro z420
    Now introducing the first mock up of my Boss Plow Quick Attach Adapter 2.0
    Basically I've plumbed the cylinders into the loader valve and removed the Boss light tower and 12v hydraulics. FYI, the tower simply detaches by removing 2 pins.
    To further shorten the attachment, I've flipped the Boss push beam and mounted it to the rear of the quick attach plate and trimmed it to fit.
    What was the push beam is now connected to the plow A-frame with brackets made from 1/2 inch steel and one-inch grade 8 bolts. Aside from the push beam, no modification has been made to any of the Boss parts. I also welded in some scrap 3/8 angle angle iron for extra rigidity.
    Tabs cut off the push beam were welded to the QA plate to hang the chain. A top-link could replace the chain if need be for down pressure, but I think I'll be happy just hanging the blade off the chain.
    Boss Plow Quick-Attach Adapter-20151105_073919-medium-jpgBoss Plow Quick-Attach Adapter-20151105_073952-medium-jpgBoss Plow Quick-Attach Adapter-20151105_074501-medium-jpgBoss Plow Quick-Attach Adapter-20151105_074617-medium-jpgBoss Plow Quick-Attach Adapter-20151105_074647-medium-jpgBoss Plow Quick-Attach Adapter-20151105_074803-medium-jpg
    The only further work I plan to do is cap off where the square tubing was cut, and then paint.
Similar Threads
  1. Quick attach subframe adapter
    By Cavalry in forum Build-It Yourself
    Last Post: 04-22-2011, 07:33 AM
  2. Quick attach adapter
    By scappoose in forum Kubota Buying/Pricing
    Last Post: 10-14-2010, 05:49 PM
  3. 3 pt adapter to quick attach
    By hawkeye08 in forum Kubota Owning/Operating
    Last Post: 08-07-2010, 02:43 PM
  4. Quick Attach Adapter for Loader
    By MA1920 in forum Attachments
    Last Post: 01-07-2007, 10:25 PM
  5. Quick-Attach adapter for 3 PH
    By jmc in forum Attachments
    Last Post: 12-22-2004, 07:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
