Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    3
    Viroqua, WI
    JD 4100
    Default JD 47" quick hitch snow blower chute
    I have a 47" snow blower on a 4100 John Deere. I have had both for a few years, but haven't needed the snow blower. My problem is that after putting on the snow blower this morning, I noticed that my hydraulic chute only moves from a few degrees to right of straight ahead, to 90 degrees to the right. Is this normal? I guess I thought it should be able to swing to the left also. Makes it a little tricky to blow snow if you can only blow it in one direction. I can take it into the local John Deere shop, but thought I would try here before spending that money.
  2. #2
    Elite Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    3,552
    central Iowa
    JD 2720
    Default Re: JD 47" quick hitch snow blower chute
    You are right, it needs adjusted. It should rotate at-least 95 degrees left and right of center.
    HAVE FUN
    Life is easier when you plow around the stumps.
    2720
  3. #3
    New Member
    Join Date
    Nov 2012
    Posts
    3
    Viroqua, WI
    JD 4100
    WOW, thanks for the quick response. I'll take a look at it and if I can't spot the problem, I'll run it in to the dealer.
  4. #4
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Will it work both ways if you just move the joystick a little bit? If so then do a search for the term "regen" for lots of reading, you can add my name if you use the advanced search.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  5. #5
    Join Date
    Mar 2008
    Posts
    599
    Doesn't this just have a cable wrapped around the chute activated by a hydraulic cylinder ? I don't see much exploration here. Unhook the cable to check the cylinder. Next stop is the cable. I wish electronic problems were this easy to diagnose.
  6. #6
    Elite Member Deere Dude's Avatar
    Join Date
    Feb 2011
    Posts
    3,279
    Beaver Dam Wisconsin then to Hohenwald, TN
    John Deere 3720
    Quote Originally Posted by Agent Blue View Post
    I would bet the cable broke. Happened to me a couple times.
    JD 3720 with R4s and bulldozer capabilities.
    X740
    13 Millimeter = 1/2"--------25 Milimeters=1"-----------100 Millimeter = 4"----------1 Meter = 40---------1 Kilometer = 3300' or 5:8 ratio
    A 13mm will but will be just slightly larger than a 1/2" nut.
  7. #7
    New Member
    Join Date
    Nov 2012
    Posts
    3
    Viroqua, WI
    JD 4100
    Thanks for all the responses. First, Kennyd, I thought you had it, but that doesn't seem to do it either. I'm fairly sure it has something to do with the cable, but danged if I can figure it out. It is not broken, and the chute swings great though the 90 or so degrees of travel it does move. I called my service guy and he seemed to think warrenty would take care of the problem so I'm headed in there today. I'll let the thread know what I find out.
    Here is a pic of the dang thing.
    JD 47" quick hitch snow blower chute-cylinder2-jpg
    Thanks again.
  8. #8
    Join Date
    Mar 2008
    Posts
    599
    Re... " My dealer thinks it is covered under warranty "
    My New Holland dealer was aware of the service problems on my TC45DA ( steering column tilt mechanism, dash fogging up, bucket cylinders slow to react, and a couple more minor items ) that was a tad over 2 years of age. They said bring it in and we will fix them. ( their shop had open spaces ) Service manager said I am sure the warranty ( which I had the extended warranty ) will cover it. Looking at their shop rate of ninety an hour I felt a bit intimidated to be stuck with a ten hour bill and parts. I had him get authorization from the zone manager .... and guess what ? They refused. The great extended warranty I had only covered major items. No estimate or partial coverage from the dealer also. I decided to make my own repairs and buy from a different agency in the future. Three years later they were not contacted for a price on my present TC 55.
  9. #9
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    759
    Northern N.B.
    2008 JD 2305, 800hr
    Is this the first time you ever use your blower? If so, by the look of your picture your chute was probably not adjust correctly when assemble the first time. When I bought my blower, the chute was not assemble, had to do it myself with the instruction that came with it. Easy to do but still took me a few try before I got it perfectly align from left to right.
    Henri
    How could you be told I was french?
    Rotary cutter 4' Howse , mid mount mower 54'' , f.e. loader 200CX , tiller RT1150 Frontier , cultivator PC1001 Frontier , middle buster PM1001 Frontier , JD 47'' front snowblower , pallet forks , 4' boxblade Agriease , grass-sweeper , quick hitch Speeco , trailer hitch , cab Jodale-Perry , trailer 16' galvanized Easy-Hauler ,
Similar Threads
  1. Need a Snow Blower Chute
    By supertaster in forum Customization
    Last Post: 03-22-2011, 09:14 PM
  2. Replies: 2
    Last Post: 09-13-2010, 12:02 AM
  3. Help-59"JD Front Snow Blower Chute Cable
    By Elmer Schmidt in forum Parts/Repairs
    Last Post: 02-04-2010, 04:47 PM
  4. Grading 47" blower on quick hitch for 54" blade???
    By Phunge in forum John Deere Owning/Operating
    Last Post: 12-07-2007, 04:01 PM
  5. Snow Snow blower chute deflector
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 01-14-2002, 02:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
