Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
  1. #1
    Join Date
    Jan 2001
    Posts
    177
    I live in the state of Delaware in New Castle County ,USA
    New Holland 1030
    Default To chain or not to chain that is the question.
    I'm debating about a set of chains for my Boomer 1030. I have some concern about clearance between the body and tires. A fellow plower stated he had a disaster when a chain came apart and tore his sheet metal up. Tension straps broke. We don't get a huge storm regularly and I do have a blower for the rear loader front set up so would chains really be needed? I have turf tires on the tractor and they seem to be better when I do plow snow. I found a set online for $132.00 plus $10.95 for keepers per side. I know alot of folks are in the snow belt so please give me your opinion. Thank's Mark
  2. #2
    Gold Member
    Join Date
    Apr 2008
    Posts
    269
    Bigfork, Mn.
    JD 4110HST
    Default Re: To chain or not to chain that is the question.
    You didn't say if you have four wheel drive, so my answer might not be relevant. I have 4x4 and turf tires. I have a pretty steep hill to climb (both in and out) and I don't have chains. Had the tractor for 8 years and never needed them. HTH
    Jim
  3. #3
    Platinum Member Buckgnarly's Avatar
    Join Date
    May 2012
    Posts
    529
    West topsham VT
    Kioti DS3510
    We can get some serious ice here early on in the Winter, the kind you cannot even stand up on. I have chains for all my plow trucks, and have no interest in EVER sliding down a hill while sitting in an open cab tractor. I have a pair of chains on the way for this first Winter with the tractor, I learned my lesson when I did not have any for my first year with the plow truck!
    If I did not have hills to deal with, I might not have the chains though.
  4. #4
    Elite Member nybirdman's Avatar
    Join Date
    Feb 2009
    Posts
    4,016
    north of upstate ny
    Kubota L4240 HSTC,L3000DT
    For what it's worth;my dealer claims turfs are better than R4 (industrial) in the snow.I have R1(Ag) with no problems.
  5. #5
    Gold Member Wyobuckaroo's Avatar
    Join Date
    Nov 2010
    Posts
    389
    Frozen bush of NW BC CA
    John Deere 2032
    Quote Originally Posted by nybirdman View Post
    I use 2 link ladder chains on 33" turfs.
    I have never had any problems with them on frozen gravel, or hard surface road.
    The ride isn't rough either. Even in the woods. I know industrial tires with ring chains on the tractor I used, are a rough ride.
    Good luck
  6. #6
    Gold Member 204saskman's Avatar
    Join Date
    Jun 2009
    Posts
    322
    Kelliher, Saskatchewan, Canada
    Montana 2844R Hst
    I got chains on my turfs. I have a loader and blower on the back and had to have them. They would just spin and then i would have no traction at all. Just my opinion but chains are worth every penny. I have mine chained all the way around so i can steer too. i found that fronts helped the most but the rears made it into a whole new tractor.
    Montna 2844R W/FEL with quick attach LDR 400hrs
    96" Home made Chain harrows
    Line ripper/trencher/ sub soiler
    Home built 10' sprayer
    72" Home built snow pusher
    72" HD landscape rake
    60" Farmking 2 stage snow blower
    55" Rototiller
    78" Bush hog disk harrow
    Quick hitch
    2002 kobelco SR35-2 mini excavator 3550 hrs
    24" tooth bucket
    16" tooth bucket
    44" clean up bucket
    Hydralic thumb
    Ripper tooth
  7. #7
    Join Date
    Sep 2005
    Posts
    139
    new brunswick canada
    bx 1830 05
    yap i got chain on my tractor last year and they will go back on its not the same tractor with chain but dont make him spin for nothing on pave driveway but you got traction with them on
  8. #8
    Platinum Member etcallhome's Avatar
    Join Date
    Mar 2005
    Posts
    655
    WV,Preston County
    JD 1026R
    Guessing your snow is different form ours. FIL had turfs on his all kind of weight on the back and could get hung up plowing snow on level driveway. It had chains on it year round couldn't even mow the yard without getting hung up. Present day has reg tractor tires on his no chains to mow but chains to plow snow.
    First yr I had my JD2210 with R4 thought OH BOY won't need chains ,till I came home one evening after snow had melted some on our concrete drive. Started to pull down toward our garage doors to back blade,, almost replaced garage door with blade down after it started to slide. Long story short CHAINS on the jd1026r R4 tires .
    Have fun and be safe !!!
    JD1026R H120 fel w/54"bucket; 60" mmm ; 260 BH/w 12" bucket; ballast box; rear weights; front quick hitch w/angling kit and 54 " blade ;3pt rear 60" blade ; JD 47" frt snowblower ; Original Tractor Cab;Bush Hog 47" tiller and 15" Middle Buster
  9. #9
    Platinum Member retiredmgn's Avatar
    Join Date
    May 2010
    Posts
    552
    Quote Originally Posted by Scaper View Post
    . A fellow plower stated he had a disaster when a chain came apart and tore his sheet metal up. Tension straps broke. .
    He must have been moving right along for chains to start destroying structure. Me, if I'm moving snow it's at a walking pace. If we have an ice storm then all bets are off for which tire tread will do best.
    None of them. Chains are required. I'll wait till I have to to put them on because they really change the ride to bumpy.
    Nelson
    Central Maine
  10. #10
    Platinum Member joeyd's Avatar
    Join Date
    Jul 2010
    Posts
    663
    North Idaho
    TYM 353HST
    Once there is snow on the ground I don't notice the bumps from the chains. I would rather get them on early than hope I don't find ice on the hill while I'm throwing snow.To chain or not to chain that is the question.-pc050154-jpg
    Isa 43:2-3
Similar Threads
  1. Northern Tool Chain versus Oregon Chain Saw Sharpener
    By nebraskasparks in forum Owning/Operating
    Last Post: 01-06-2012, 10:06 PM
  2. B7800 easy chain saw and chain saw holders
    By recodaza in forum Kubota Owning/Operating
    Last Post: 02-21-2007, 08:06 AM
  3. Chain Saw Question
    By proudestmonkey in forum Kubota Owning/Operating
    Last Post: 06-10-2006, 01:49 PM
  4. Replies: 5
    Last Post: 01-16-2006, 11:57 AM
  5. Chain Gurus--"Transport" chain useage?
    By bigpete in forum Owning/Operating
    Last Post: 02-21-2003, 02:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
