Results 11 to 17 of 17
11-18-2012, 11:46 AM #11
Re: front mount snowblower
In a lot of ways it's like my deere hitch. The front arms even disconnect at the same spot. Because of this the loader can be attached with 90% of the hitch still left on the tractor. I also like how they use 2 hydraulic cylinders instead of one, very well built!
JD Cabbed 3720, 3rd Function, 59" Front Mt. Blower, 72d MMM auto-connect deck.
11-18-2012, 12:31 PM #12
Nice set up. How long was the install time for hooking the system up? And when you switch from FEL to Zuidberg , approx how long to do that?
TN75D, w/cab, FEL, BH
7 1/2 ft Lucknow Blower
11-18-2012, 01:24 PM #13New Member
- Join Date
- Mar 2011
- Posts
- 10
- Tractor
- New Holland 3050
nice lineup of equipment and yes, i will take some vid... good luck, nice to hear from you
11-18-2012, 01:26 PM #14New Member
- Join Date
- Mar 2011
- Posts
- 10
- Tractor
- New Holland 3050
id like to know more about yours too...is it pto driven???
11-18-2012, 03:46 PM #15
Me gravelman?
If so yes, the deere units are pto driven. This unit comes from the mid pto and not the rear pto. From the mid pto there is a long driveshaft that goes to a front cage that houses two bearrings. It then, goes throught those two via another shaft and onto the blower. There are controls (a lever) inside the cab that allows for three different positions. 1) Rear pto 2) mid mt. pto and 3) rear/mid together. I guesing # 3 would come in handy if you wanted to run a rear mounter sander/salter while blowing snow.JD Cabbed 3720, 3rd Function, 59" Front Mt. Blower, 72d MMM auto-connect deck.
11-18-2012, 04:01 PM #16
11-19-2012, 02:27 PM #17New Member
- Join Date
- Mar 2011
- Posts
- 10
- Tractor
- New Holland 3050
ok, thanks very much...i would say that was alot lesss expensive and easier to install than my unit...good luck with it..keep in touch
Similar Threads
Snow Can I Mount A Front Mount Snowblower Attachment With The BackHoe Still On My 2520
By coollx in forum John Deere Owning/OperatingReplies: 4Last Post: 04-22-2011, 02:47 PM -
Front-mount snowblower - again
By JCA in forum Kioti Owning/OperatingReplies: 0Last Post: 03-24-2004, 01:47 PM -
BX Front Mount Snowblower!
By the_g in forum Kubota Owning/OperatingReplies: 26Last Post: 02-29-2004, 07:59 AM -
By Deerlope in forum Kubota Owning/OperatingReplies: 6Last Post: 11-29-2003, 05:47 AM -
Snowblower NH front mount snowblower
By Rowski in forum AttachmentsReplies: 0Last Post: 01-07-2002, 07:26 PM
