Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Damage free cutting edge?
    Quote Originally Posted by KYDan View Post
    This was on the old gravel and chip and seal roads. I don't think they do that anymore, all the roads are now asphalt.
    'slag' roads are alive and well and still put in daily in many areas.
    It's a low(er) cost alternative to a conventional asphalt topped road, and in many cases has near the same service life on low traffic roads, as asphalt... and protects the subgrade and is a good sub base, should the municipality find money to cap it later.
  2. #12
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Quote Originally Posted by Soundguy View Post
    There's a plenty of slag roads around here. Lots of Amish.
    Murph
  3. #13
    Member
    Join Date
    Oct 2009
    Posts
    37
    gwinn mi.
    If you use plastic pipe run it through a table saw. As you cut it turn it a little at a time so its not a straight cut. Stays on the cutting edge without sliding off.
  4. #14
    Join Date
    Jun 2004
    Posts
    2,409
    USA
    Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
    Default
    The county road crews used to use a 1" X 4" length of oak board instead of the metal cutting edge on the graders and truck plows and it worked fairly well. This was on the old gravel and chip and seal roads. I don't think they do that anymore, all the roads are now asphalt.
    Loving this idea!!!
  5. #15
    Platinum Member kw22614's Avatar
    Join Date
    Dec 2012
    Posts
    548
    Manassas, VA
    Kubota BX1860
    Quote Originally Posted by camer View Post
    makes sense that it'll hold better. my bucket's 5' wide so my plastic pipe'll be a little shorter, but how much is a little from straight cut? got a pic? thanx
  6. #16
    Elite Member
    Join Date
    Mar 2005
    Posts
    2,762
    Bedford, VA
    John Deere 2320
    I added a 2x6 below the cutting edge and it work pretty good for the past 3 yrs.. I used a 2x6 so i could reverse it if the edge got worn down too much..
    I used 4 or 5 3/8" bolts to hold the board in place - my rear blade is homemade and doesnt have a bolt-on cutting edge.
    brian
    Bedford, VA
    2320 w/ 62D MMM, 200CX FEL, Pats EZ Change, LX4 Cutter
    Co-owner (with my father) of John Deere 790, 30 HP, 4x4, 513 cutter, 70 FEL
    2012 Nissan Xterra Pro-4x
  7. #17
    Join Date
    Jun 2004
    Posts
    2,409
    USA
    Default
    Quote Originally Posted by thatguy
    brian
    U just using a 2x6 pine board? I like this idea even more!!! Lol!
  8. #18
    Veteran Member srs's Avatar
    Join Date
    Feb 2004
    Posts
    1,073
    Jarrettsville Maryland
    Kubota B3030 HSDC
    Quote Originally Posted by PapaPerk View Post
    I would like to use it for snow removal on my concrete driveway.
    Any suggestions for a cutting edge or other method to prevent the blade from ripping and hanging up on my expensive drive? Thank u!
    Papa, here is what I use. I got the piece of used rubber off a county roads snow plow. A friend of mine worked for the county years ago and gave me this piece. It was (I think 8 feet long) and I cut it down. They were throwing them in the dumpster. It had very little wear on it and for the few driveways I plow this will last a lifetime.
    Attached Thumbnails Attached Thumbnails Damage free cutting edge?-rubber-edge-copy-jpg
    Stanley----Kubota B3030 HSDC
  9. #19
    Elite Member
    Join Date
    Mar 2005
    Posts
    2,762
    Bedford, VA
    John Deere 2320
    Yes.. just a pressure treated 2x6 hold in place by a few bolts..
    I also added the same thing to the bottom of the FEL for the same purpose.. I use the FEL for paved driveways and the rear blade for the gravel ones in the neighborhood..
    Both will still scrape some of the sealer off the asphalt driveway in spots, BUT there is no way it can 'dig in' to the asphalt..
    Brian
    Bedford, VA
  10. #20
    Member
    Join Date
    Oct 2009
    Posts
    37
    gwinn mi.
    Quote Originally Posted by kw22614 View Post
    A 1/2 inch in 5 feet should be good.
Similar Threads
  1. Loader Cutting edge?
    By dirtdevil911 in forum Kioti Owning/Operating
    Last Post: 12-27-2012, 05:10 PM
  2. Will not enough clutch free play cause damage?
    By edrobyn in forum New Holland Owning/Operating
    Last Post: 11-18-2011, 05:35 PM
  3. New cutting edge
    By ark1stclass in forum New Holland Owning/Operating
    Last Post: 03-08-2011, 10:10 AM
  4. poly cutting edge
    By drz400 in forum John Deere Owning/Operating
    Last Post: 12-05-2009, 11:02 PM
  5. Cutting edge wear
    By billfires in forum Owning/Operating
    Last Post: 03-14-2003, 09:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
