Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Gold Member kw22614's Avatar
    Join Date
    Dec 2012
    Posts
    264
    Manassas, VA
    Kubota BX1860
    Default Re: Damage free cutting edge?
    Quote Originally Posted by camer View Post
    A 1/2 inch in 5 feet should be good.
    Thanks, I got about a 4&1/2' piece of 2"ID, white, schd 40 pvc laying around. Think I'll experiment with that to test the theory.
    Thanks, camer!
  2. #22
    New Member
    Join Date
    Mar 2011
    Posts
    17
    Western New York
    Kubota L3240 HTSC, Ford 1510
    I got a piece of 1 1/2 inch by 8 inch rubber that had slots punched in it for my 8 foot rear blade. I got it at plowrubber.com. It should last forever and does a great job without damaging the driveway.
  3. #23
    New Member
    Join Date
    Dec 2010
    Posts
    2
    JD 1050
    It is 1.5" black PVC pipe slit down the length and two holes drilled on each end. The bungee strap hooks in one hole goes over the blade and hooks in the other hole. You can plow in either direction and it does not come off.Damage free cutting edge?-img_0276.jpgDamage free cutting edge?-img_0273.jpgDamage free cutting edge?-img_0275.jpg
  4. #24
    Silver Member farmeratheart's Avatar
    Join Date
    Aug 2008
    Posts
    186
    MD
    JD2305
    Quote Originally Posted by Professor Marvel View Post
    I have read here that some people suggest getting a stall mat from Tractor Supply and cut strips ands sandwich it between the cutting edge and the blade with a couple inches sticking out. This sounds like a great idea and I plan on trying it as soon as we get snow. I think it should also help on gravel and not gouge the gravel up. I plan on using it on my front blade but it should work great on either end of the tractor.
    I was one of the ones who did it this way a couple of years ago. Search on my posts by username and I'm sure that you will find it. My favorite part of this mod is that I can plow from the blacktop driveway right up onto the lawn without hurting the turf.
    Farmeratheart (Frank)
  5. #25
    Platinum Member Iowachild's Avatar
    Join Date
    Feb 2006
    Posts
    934
    NW PA
    Kubota B2320HST
    Search for both polyurethane (pricey) and rubber (more reasonable) plow edges. You will find both in several thicknesses and widths. I just ordered 3/4" X 4", 725 psi rubber edge for my Wheelhorse plow today from Rubbercal.com today. They are 25% off right now!
    MIKE
    Ephesians 6:12
    America is a Constitutional Republic.......NOT a democracy! Our founder knew democracies never last!
    "Iowa Child" by Sarah Hall Manley
  6. #26
    Join Date
    Oct 2010
    Posts
    240
    Virginia near Culpeper
    Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM
    Quote Originally Posted by farmeratheart View Post
    Do you think it will work well on gravewl also?
    Thanks for the idea.
    Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer--- STUFF THAT GOES ON EM
    Pay no attention to the man behind the curtain
Similar Threads
  1. Loader Cutting edge?
    By dirtdevil911 in forum Kioti Owning/Operating
    Last Post: 12-27-2012, 05:10 PM
  2. Will not enough clutch free play cause damage?
    By edrobyn in forum New Holland Owning/Operating
    Last Post: 11-18-2011, 05:35 PM
  3. New cutting edge
    By ark1stclass in forum New Holland Owning/Operating
    Last Post: 03-08-2011, 10:10 AM
  4. poly cutting edge
    By drz400 in forum John Deere Owning/Operating
    Last Post: 12-05-2009, 11:02 PM
  5. Cutting edge wear
    By billfires in forum Owning/Operating
    Last Post: 03-14-2003, 09:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
