Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    New Member
    Join Date
    Jan 2013
    Posts
    21
    NB Canada
    Massey Ferguson 184-4
    Default MK Martin Snowblower not shooting far??
    I have a MK Martin 7' blower and I find it does not blow very far (5 of 6 feet), even with dry snow. How many RPMs should I be running at? If anyone has a blower similar, what hole do you put the chute adjustor at? What usually causes a blower to no shoot snow far? Are these supposed to be a good blower?
    Thanks
  2. #2
    kco
    kco is offline
    Join Date
    Jun 2004
    Posts
    661
    Armstrong, BC
    Kioti DK35 SE HST (2011)
    Default Re: MK Martin Snowblower not shooting far??
    I have an MK Martin 75" pull-type which looks to be the similar to yours, only reversed for pull-type. I normally run it at the rated 540 RPM. It throws the snow a good 30' to 40' in virtually all snow conditions, even very wet, cement-like snow. My tractor is a DK35HST with about 28 PTO hp. I usually have the chute set one hole shorter than the straightest setting.
    My 4-blade fan is 23" diam x 8" deep. It looks like your 87" blower fan would have a 27" x 10" deep.
    I think it is best to keep the RPM's at rated PTO speed.
    Here are some photos of mine in a fairly light, dry snow--but it works as well in wet snow:
    MK Martin Snowblower not shooting far??-r20111228_snowblower_2.jpgMK Martin Snowblower not shooting far??-r20111228_snowblower_3.jpgMK Martin Snowblower not shooting far??-r20111228_snowblower_4.jpg
    EDIT: Here are a couple more from this year in wetter snow:
    MK Martin Snowblower not shooting far??-img_1586.jpgMK Martin Snowblower not shooting far??-img_1603.jpg
  3. #3
    New Member
    Join Date
    Jan 2013
    Posts
    21
    NB Canada
    I'll have to watch the RPMs more closely and adjust the chute... I'll try that Thanks
  4. #4
    Elite Member MIKE R's Avatar
    Join Date
    Sep 2010
    Posts
    3,615
    PRINCE TOWNSHIP, ONTARIO
    MASSEY 1020 and 1945 CASE SC, 1914 1 1/2 hp EMPIRE HIT AND MISS ENGINE
    Keep it up at the rated 540rpm and make sure there is not any rust in the chute and the impeller clearance is no more them 1/4" to 3/8".
    On my Meteor snow blower there is a 3/4"-7/8" gap around the impeller. When I get time I plan on bolting on old heavy belting to compensate for the clearance and act as a sacrificial wear piece.
    "If the women don't find you handsome, they should at least find you handy" - Red Green
    PRINCE TOWNSHIP TRACTOR CRUISE WEBSITE
    https://sites.google.com/site/prince...torcruise/home
  5. #5
    Elite Member
    Join Date
    Aug 2004
    Posts
    2,758
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Quote Originally Posted by MIKE R View Post
    I need to do the same thing. Gravel tends to do that.
    Rather than belting I plan to use about 1/4" poly sheeting as it is more 'non stick' and slippery. (think kid's plastic sleds)
  6. #6
    Gold Member
    Join Date
    Mar 2007
    Posts
    353
    British Columbia, Canada
    1959 MF-65 sold, 2007 Jinma 554 diesel.
    I did same with my old (1986) Allied/Farm King snow blower. In my case I used 1/4" mild steel flat bar and set the clearance to clear the housing surface by about 0.030". It works fine and has inproved my throwing distance considerably. I use both the 540 and 720 speeds I have on my tractor depending on the snow and weather conditions. Either way, the snow gets thrown away from the driveway.
    To OP - if your clearances are good then you need to increase the PTO speed accordingly.
    Attached Thumbnails Attached Thumbnails MK Martin Snowblower not shooting far??-snow-blower-2.jpg
    2007 Jinma 554 tractor, FEL, 8ft Rear Blade, 73" Snowblower, 2002 3500 Dodge Ram 4x4, 1986 F250 4x4 SC 6.9 turboed diesel.
  7. #7
    Gold Member
    Join Date
    Apr 2012
    Posts
    341
    Northern Ontario, Canada
    2012 Kioti CK27HST
    My front mount throws the snow about 10-12' away with the chute in the second hole from the top. I run my RPM according to the tach at 2500. I have a MK Martin Meteor, too. Mine is a 63" I think.
  8. #8
    Bronze Member Phil48's Avatar
    Join Date
    Mar 2012
    Posts
    76
    Eastern TownShip
    CK20 HST
    If I remember correctly my dealer did install a larger triangular plate of metal in front of the fan. You can see the shinny new bolt on the pic. It's not bigger by much but it does help. It doesnot throw snow very far indeed but when it's only 10 feet away I can pick it up again and re-blow it again and the tractor doesnt mind it's very powerfull (51 inches). So far it's working flawless. The front chain does also help a lot for steering.
    Phil
    Attached Thumbnails Attached Thumbnails MK Martin Snowblower not shooting far??-souffleur-martin-action.jpg
    Phil
  9. #9
    Join Date
    Mar 2012
    Posts
    76
    Eastern TownShip
    CK20 HST
    Quote Originally Posted by doxford jim View Post
    great modification, I will do it for next year!
    Phil
    Phil
  10. #10
    Veteran Member Dutch445's Avatar
    Join Date
    Aug 2001
    Posts
    1,857
    Upstate NY
    JD X585
    phil was that pic taken while the blower was running?
    JD X585 with 45 loader, 3ph, 62C deck, 47SB, 54 blade, Soft Cab. JD F525 with 48". JD 4X2 gator. JD T23 trimmer
    JD CS56 and CS36 saws. JS35 WB mower.
Similar Threads
  1. MK Martin SB68 3pt snowblower
    By botayota in forum Attachments
    Last Post: 11-02-2011, 09:12 PM
  2. Snowblower MK Martin vs Lucknow snowblower on DK35 HST
    By kco in forum Attachments
    Last Post: 07-13-2011, 02:26 PM
  3. Snowblower Snowblower - Allied Buhler versus Mk Martin Meteor
    By zkurtb in forum Attachments
    Last Post: 11-06-2009, 09:48 PM
  4. Martin Houses
    By dooleysm in forum Rural Living
    Last Post: 08-15-2008, 09:37 AM
  5. New Martin house..
    By Vern1 in forum Projects
    Last Post: 02-14-2008, 02:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
