Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    New Member
    Join Date
    Jan 2013
    Posts
    21
    NB Canada
    Massey Ferguson 184-4
    Default Bucket vs Snow Pusher
    What is better, a bucket or snow pusher? I've seen some pretty nice pushers on here, might consider making one myself.
  2. #2
    Veteran Member nybirdman's Avatar
    Join Date
    Feb 2009
    Posts
    1,487
    north of upstate ny
    Kubota L4240 HST Cab
    Default Re: Bucket vs Snow Pusher
    As far as I can see the only use for a pusher would be in a parking lot.With a lite materials bucket you can pick it up and move.Standard duty buckets,for the most part don't have enough volume.They are better than a shovel.
  3. #3
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    11,418
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC 2042
    I'd pick snow pusher over bucket..for I have place to stack snow no need to bucket away,also less passes w/pusher compare to bucket.
  4. #4
    TWD
    TWD is offline
    Join Date
    Jul 2010
    Posts
    227
    Sierra Nevada Mountains - CA
    Kubota M59
    I like my bucket. When we get big storms I have to be able to lift the snow up and dump it on top of some areas that can't be pushed.
    IE: In front of my driveway I can only push across the street so long until it's 6' tall, and then I have to lift it and dump it on the opposite (my side) which has a 3-4' dirt wall depending where I dump.
    The bucket also makes it fun for snow cave building and such
    If I had a place to push, and was on flat ground I'd go pusher probably... down the road when we pave I plan to go with a blower! Now it's out of the way for good
  5. #5
    Veteran Member escavader's Avatar
    Join Date
    Mar 2005
    Posts
    2,022
    western maine
    bx-23 ,
    i have both snowpusher goes on and off within a minute.SNOWPUSHER HANDS DOWN.yOUD BE SURPRISED TO SEE HOW MUCH HIGHER YOU CAN STACK IT WITH A PUSHER. With the side wings you dont start loosing it off the sides ,and can even keep it contained going around a corner.
    ALAN
    KUBOTA BX-23,Block heater, AG TIRES[rears filled],MECHANICAL THUMB,SALSCO CHIPPER,WOODS LRC60 LANDSCAPE RAKE WITH GAUGE WHEELS,,HOMEMADE BUCKET FORKS,QUICK HITCH FOR 3 POINT HITCH,HOMEMADE FRONT BUCKET MOUNTED QUICK HITCH[for 3 point implements], FARM FORCE 6 FT 3 POINT BLADE,MARKHAM TOOTHBAR,HOMEMADE TRAILER HITCH FOR BACKHOE, HOMEMADE HEATED STEEL AND FIBERGLASS CAB,54 INCH PRONOVOST PUMA 3 POINT SNOW BLOWER,WITH HYDRAULIC CHUTE CONTROL,REAR TIRE CHAINS,UPGRADED 40 AMP ALTERNATOR,4-55W LIGHTS
  6. #6
    TWD
    TWD is offline
    Join Date
    Jul 2010
    Posts
    227
    Kubota M59
    Can you lift it with a pusher or just push it so it builds up? I didn't think you could lift with a pusher ???
  7. #7
    Gold Member Piperflyer's Avatar
    Join Date
    Dec 2006
    Posts
    254
    USA
    Kubota3030HST
    allot of times when the snow isn't that deep I just push it with the blower attachment. It acts as a box blade and will pile the snow up.
    'Life's Journey is not to arrive at the grave safely in a
    well preserved body, but rather to skid in sideways, totally worn out, shouting, 'Holy S... What a Ride!!
  8. #8
    Join Date
    Mar 2005
    Posts
    2,022
    western maine
    bx-23 ,
    yes ,you can,mine mounts on the front of my bucket ,i can get the bankings pushed up 3 to 4 ft higher with it on
  9. #9
    Join Date
    Jul 2011
    Posts
    67
    Billings, MT
    kubota L3400, Farmall 'A', Farmall F-14, Ford 860, JD 4520
    I can move snow a lot faster with a blade then I can with the bucket. The bucket on my tractor is only 5' wide where the dozer blade is 7' wide. I dont need to pile snow up anywhere otherwise a bucket might be better for that. Just my .02 cents.
    Steve
  10. #10
    Gold Member
    Join Date
    Nov 2008
    Posts
    403
    Maine
    '09 JD 5105M Cab & '05 JD 4720 Cab
    Reversible pusher, also called a push-pull blade, is by far my favorite snow-clearing front implement. Like mentioned above when used properly you can pile up a lot of snow with it and in pull mode you can reach near buildings and other areas that would otherwise require a walk-behind blower or a shovel to clear properly. One caveat though, in order to maximize efficiency a rear blower must be used in conjunction with a push-pull.
    JD 5105M & JD 4720 Cabbies w. Shoule reversible snow blade/Shoule rear snowblower; Pronovost blower; backhoe and some attachments I have no idea what they are for.
Similar Threads
  1. Snow pusher
    By CJONE in forum Snow Removal
    Last Post: 11-16-2012, 09:14 AM
  2. Snow pusher.
    By lawn_king in forum Kubota Owning/Operating
    Last Post: 01-09-2012, 03:16 PM
  3. Snow Attachments Snow pusher
    By Camo in forum Snow Removal
    Last Post: 01-30-2010, 02:08 PM
  4. Snow Pusher
    By ttowne66 in forum Build-It Yourself
    Last Post: 12-27-2007, 07:15 PM
  5. Backhoe Bucket Snow Pusher
    By GoodGuy in forum Build-It Yourself
    Last Post: 10-19-2004, 07:59 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
