tessiers
- Joined
- Sep 22, 2007
- Messages
- 728
- Location
- Central Maine
- Tractor
- 05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
I can get some tomorrow.
I'm still hopeing to hear from people that have actually bent their loader. I'd like to see what gave way first. On my old David Brown the cross brace at the front of the loader was bolted in, not welded and had a bit of play in it. If you dug a lot with one side of the bucket you could rack the arms a couple of inches but just switching sides for a while would rack it back. I tended to favor using the left side as the control levers were on the right frame post and blocked the view.
Maybe the concept of a "bent loader arm" is based upon false premises and is thereby more legend than fact. If (for the sake of the argument) most people who frequent this site come either to obtain and/or share knowledge, then that could indicate thoughtfulness rather than recklessness. If that is the case, the cross-sectional sample obtained would not have sufficent idiocy to provide the proper amount of damage desired.
how fast can one go pushing a bucket into a gravel pile? 2-3mph?
Always wondered how putting all that force on the bucket hydraulics
worked in the long haul. Seemed to me that the hydraulics would cushion the
impact but clearly bent or cracked arms are a reality.
Seems reasonable to expect any modern well made implement to not crack or bend structurally at full load,
or even something over that. I'd expect movement to stop, but not metal to break.
Now i guess if you run your tractor and loader into a tree at 15 mph, anything goes.
But short of a higher speed collision with something or a tractor upset or rollover, that steel should handle it.
Shouldn't it?
